Pump to motor
/ Pump to motor #1
Lea
Fort Frances Ontario
john Deere model M kabota 2320 TLB
I have two commercial shearing pumps that are identical, my question is can I run one pump and pump to the second to run it as a motor. The specs are:
Max rpm 2000 @ 80gpm
Pressure-2000psi
Torque 2560 in/lbs@ 1800rpm@ 2000psi
Power 73hp
Input flow 76 gpm
Please weigh in and tell me if this is possible
What I want to do is build a firewood processor and this would turn a 42-48" circular saw
Thanks
Lea
/ Pump to motor #2
Unless those pumps have the option for an external case drain they can not be used as motors. If they have an external case drain option their is a possibility that they might work as motors. I suspect these are pressure side loaded pumps so would also suspect the motor would only operate in one direction.
/ Pump to motor #3
Just an observation, most of the circular saw models I have seen are belt driven directly from the motor. A much more effective use of horsepower.
If you have the power it can certainly be done. It would certainly be easier from a build standpoint.
/ Pump to motor
Wild Bill
I have lots of power to run a pump 345cu in international industrial engine so power should not be a problem. It is also set up with a twin disc clutch, but I don't think I really need the clutch
I can run the pump direct off of motor. I have lots of parts that is why I am leaning toward hydraulic saw
2014 CASE IH Magnum 340 AFS (A63111)
2014 CASE IH...
2018 Monroe Towmaster TC-16 10 Ton Tag A Long Trailer (A61573)
2018 Monroe...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
(4) 5.00-10 TRAILER TIRES (A64281)
(4) 5.00-10...
