Pump size for log splitter
/ Pump size for log splitter #1
John123
I am building a log splitter and was wanting to know what is the biggest pump size i can use on a 6 1/2 HP motor?
Thanks!
/ Pump size for log splitter #2
Welcome to TBN:D
Look at these Calculators (on the left) and pick the Pumps & Motors one...should tell you all you need. Also these Calculators are very helpful.
Thanks, i was looking for something like that.... That will help alot. :)
/ Pump size for log splitter #4
The defined answer is, if you use a single stage hydraulic pump, it will be slow. A 7 HP engine running at 360o rpm, can run a .2 cu in pump, and produce 3.2 GPM. Using a 4 in cyl. Cycle will be 55.2 sec. Force applied will be about 18.5 ton
A two stage hydraulic pump will provide more GPM's because the first stage is pumping fluid at a lower pressure about 650 psi, and more GPM, At a set psi point, the pump will automatically shift to high pressure, 2500 psi and low GPM,s. Pressure determines power, and GPM determines speed of cyl operation.
https://www.surpluscenter.com/item.asp?UID=2009110606233380&item=9-7503-13&catname=hydraulic
The 13 GPM 2 stage pump, using the 6.5 HP engine. Force applied, 15 ton.
The cycle time of a two stage pump will vary based on the time the pump stays in the fast mode. If you are splitting very hard or stringy wood, the cycle time will slow down .
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
karcher pressure washer (A61567)
karcher pressure...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
Challenger MT400 and MT600 series tractor parts manuals (A63117)
Challenger MT400...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
