pump shaft splines are worn out
   / pump shaft splines are worn out #1
augercreek
duluth mn
f12 farmall100,h
i have a Vickers dual pump on my wood processor and the splines have worn off.Is there any way to fix this?New shaft?Who has parts?The pump is a V2525VQ 17A14 11CC 20L X7 0X. I'd sure like to fix this one as new are very pricey.
   / pump shaft splines are worn out #3
You can get the shaft and the seals from FEI out of Valley city ND whom are AGCO dealers . Sometimes you can get by just replacing the shaft , but I found that if the splines are worn then you will have internal wear also,because of side load or vibration..
I'll be calling them tomorrow,thanks much.
Well guys I got a new shaft and seal,bearingnand o rings,and we are back in business! All for $159. Thanks again
UNUSED LANDHONOR LHR-RF24 RATCHETS & TOOLBOX (A54757)
UNUSED LANDHONOR...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
378467 (A51572)
378467 (A51572)
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2020 FREIGHTLINER M2 106 BOX TRUCK (A54607)
2020 FREIGHTLINER...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD72...
