pump shaft splines are worn out
   / pump shaft splines are worn out #1
augercreek
duluth mn
f12 farmall100,h
i have a Vickers dual pump on my wood processor and the splines have worn off.Is there any way to fix this?New shaft?Who has parts?The pump is a V2525VQ 17A14 11CC 20L X7 0X. I'd sure like to fix this one as new are very pricey.
   / pump shaft splines are worn out #3
You can get the shaft and the seals from FEI out of Valley city ND whom are AGCO dealers . Sometimes you can get by just replacing the shaft , but I found that if the splines are worn then you will have internal wear also,because of side load or vibration..
I'll be calling them tomorrow,thanks much.
Well guys I got a new shaft and seal,bearingnand o rings,and we are back in business! All for $159. Thanks again
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2018 INTERNATIONAL 4300 26' REEFER BOX TRUCK (A54607)
2018 INTERNATIONAL...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2009 John Deere 1050J Crawler Tractor Dozer (A52377)
2009 John Deere...
