pump shaft splines are worn out
   / pump shaft splines are worn out #1
augercreek
duluth mn
f12 farmall100,h
i have a Vickers dual pump on my wood processor and the splines have worn off.Is there any way to fix this?New shaft?Who has parts?The pump is a V2525VQ 17A14 11CC 20L X7 0X. I'd sure like to fix this one as new are very pricey.
   / pump shaft splines are worn out #3
You can get the shaft and the seals from FEI out of Valley city ND whom are AGCO dealers . Sometimes you can get by just replacing the shaft , but I found that if the splines are worn then you will have internal wear also,because of side load or vibration..
I'll be calling them tomorrow,thanks much.
Well guys I got a new shaft and seal,bearingnand o rings,and we are back in business! All for $159. Thanks again
Caterpillar 420F2 IT (A53314)
Caterpillar 420F2...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
2008 Caterpillar 303.5C Mini Excavator (A52377)
2008 Caterpillar...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
