Pump RPM recommendations
/ Pump RPM recommendations #1
James Eric
This is the pump that I own:
Specifications
Rated pressure: 2900psi.
Displacement .3759 cu. In/rev
Shaft: 1/2" keyed.
Ports: SAE 3/4-16 inlet: 9/16-18 outlet.
Rated RPM: 2000, Max RPM 4000
Part Number CB1A-F6SA
Are there any advantages or dis-advantages to running the pump at 2720 RPM in stead of 2000 RPM?
I am using it to power a Danco loader on a cub cadet 1250 tractor. My target lifting capacity is 400-500 pounds.
2040 RPM = 3.31 GPM
2720 RPM = 4.42 GPM
I plan to use 3/8" lines and run the PSI between 1200-1400.
What do you think?
Thanks,
James
/ Pump RPM recommendations #2
Pump speed will only change the max speed cylinders move. Does not affect the pressure (lift capacity).
Thanks. Maybe I should have been clearer with my questions.
1. Will the increased speed shorten the life of the pump?
2. Is the increased GPM flow worth the extra RPM's based on my target lifting goals?
James
/ Pump RPM recommendations #4
As long as you don't cavitate the pump inlet there would be very little change in life expectancy.
Recommended max flow rate for suction hoses is 4 feet per second. To get this flow rate you would need a minimum of 5/8" ID hose for the inlet.
3/8" hose is good for about 1.3 GPM at 4 FPS.
Roy
Thanks. That is very helpful. I will use a larger suction line.
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
PEQUEA TT4100 TURBO TEDDAR (A64277)
PEQUEA TT4100...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
90in. Work Bench (A65640)
90in. Work Bench...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
