3-Point Hitch pump noise
/ pump noise #1
kobesan
Kubotal245DT
lt 235 hydraulic pumps starts to screech when hitch lever is all the way up and quiets if lever is moved back a bit
/ pump noise #2
The screech is usually the relief valve - backing it off a bit is the right thing to do.
/ pump noise
Thank you
/ pump noise #4
If it's your 3 point, there should be an adjustable link that you can set so it doesn't hit relief when the hitch is empty and at the top. Check for something like that. Pumping the oil over relief generates a lot of heat so it is best to get it all adjusted so you don't accidentally forget and run with the oil going over relief.
/ pump noise
I will check that out and let you know.
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
Ford F800 (A63689)
Ford F800 (A63689)
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2017 Ford F-250 Single Cab Reading Service Truck (A61573)
2017 Ford F-250...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
