3-Point Hitch pump noise
   / pump noise #1
kobesan
Kubotal245DT
lt 235 hydraulic pumps starts to screech when hitch lever is all the way up and quiets if lever is moved back a bit
   / pump noise #2
The screech is usually the relief valve - backing it off a bit is the right thing to do.
   / pump noise
Thank you
   / pump noise #4
If it's your 3 point, there should be an adjustable link that you can set so it doesn't hit relief when the hitch is empty and at the top. Check for something like that. Pumping the oil over relief generates a lot of heat so it is best to get it all adjusted so you don't accidentally forget and run with the oil going over relief.
   / pump noise
I will check that out and let you know.
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
2121 (A51244)
2121 (A51244)
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
Homemade Trailer (A50322)
Homemade Trailer...
2015 CATERPILLAR D6T XL HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
Super Material Lift MH1000 (A52128)
Super Material...
