Pump for Yanmar 2210
/ Pump for Yanmar 2210 #1
freestoneflash
teague texas
yanmar 2210
It seems I need a Hydraulic pump for my Yanmar 2210; Was told the housing had a crack; The price for a new one is way to much since I had to buy a new radiator for about $250 --Anyone know of where to find one ? Hoye Tractor is High, Wants to sell you new. What about a salvage yard? HELP
/ Pump for Yanmar 2210 #2
I would not buy a used pump unless I intended to sell the tractor.
Where is the pump for the Yanmar mounted and how is it driven? If you posted photos of the pump, that would help immensely. If you have specs for the hydraulic system, then that helps also.
It may well be that you can substitute a slightly different pump for the OEM one. More information, please.
/ Pump for Yanmar 2210 #3
Do a google seach for tractor salvage yards, there a few around.
/ Pump for Yanmar 2210 #4
I have a question for you. How would a salvage yard determine the true condition of a used hydraulic pump?
/ Pump for Yanmar 2210 #5
The answer is, you would never know the condition of a used part.
You could however test it for flow and pressure.
/ Pump for Yanmar 2210 #6
There are several yanmar salvage yards around southern global is 1.. west Kentucky tractor parts is another. google them for their ph#
/ Pump for Yanmar 2210 #7
Just the same way that you buy anything used.
/ Pump for Yanmar 2210 #8
Keep in mind that this is just a discussion.
Yes... it could be put on a flow bench and tested.
But to do that, it would have to be removed from the tractor, paid for in full and then taken to the shop for testing. Now, I do not know of any shops that work for free. It does take time to first identify the pump being tested, look up the specs for that pump, hook it up to the flow bench and run the tests. It is common to issue a report in writing on the findings.
So after doing all of this and finding out that the pump is marginal at best, then what? Will the wrecking yard refund the price paid for the pump in full? Who will eat the cost of the flow bench test?
Lastly, if a brand new pump can be had for $250.00, then where is the logic in buying a used pump?
If the subject machine was a hydrostatic drive crawler loader and the pump cost 3 grand brand new, then that would be different, especially if the pump was proprietary. Perhaps the pump for this little tractor is not proprietary and a common off-the-shelf SAE A pump from Surplus Centre will fill the bill. Is it not logical to explore that option first before scouring the countryside for pump that may be almost as worn out as the pump it is replacing?
/ Pump for Yanmar 2210 #9
And what way is that? Explain to me how YOU would determine how good a hydraulic pump is, while it is sitting in a dead tractor?
I am about ready to sell out, everything; Got front end loader, rake, cultivater,mower and blade. I have let it set up for about 16 - 18 months; Tractor under shed; I have 16 ft. trailer that I have hauled all my stuff on to my daughters place; Will keep trailer if someone wants to buy tractor and implements. If you hear of anyone interested , give them my number; 903-388-4058
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
