Pump Failure after thumb install
/ Pump Failure after thumb install #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
I had a pump failure on my mini excavator after about 30 hours of a thumb install.. It may have nothing to do with it but I want to pick a few brains. I have a spare circuit on my spool block that can my plumbed for a hammer or whatever. I only planned on using it for a thumb. I plumbed it from one port to a relief and to the closing side of the cylinder. The relief is tee d back to the tank. The retract side is just plumbed to the other side of the spool.
The reason I put the relief in line was if I grab something and curl the bucket too much is will open the relief before it will bend a thumb cylinder. Also is you squeeze the object it will relief.
Here is my question. If I grab a log and I squeeze it with the bucket and it rolls back the thumb cylinder. It will open the relief. Now it pushes the fluid out of the cylinder to the tank. Now the cylinder acts bouncy till I cycle it a few times. Does this hurt anything? Introduce air into the system or a void of fluid I had the relief set at 1500lbs and excavator runs at 3000lbs.
It may be a total fluke but figured I would ask.
/ Pump Failure after thumb install #2
Racer,
Since the relief is venting oil back to tank and there is no oil going into the other end of the cylinder you are drawing a vacuum and filling that end with air. And option would be to install an anti-cavitation check valve to the opposite end of you cylinder. This check would connect tank to the cylinder work port and allow the cylinder to drawn oil in while it is being forced open.
I would suspect the pump failure was just a fluke.
/ Pump Failure after thumb install #3
You may also be able to adjust one side of the valve for the thumb and not need another relief valve we do that with all the excavators we install thumbs on.
/ Pump Failure after thumb install #4
You could also switch to a crossover relief valve, which connects both ends of the cylinder to each other and vents between them when the pressure is reached, rather than back to tank. That would help supply "make up" oil to the other side of the cylinder as the relief hits, and you could still have it set lower than your main system relief pressure so the bucket cylinder could push harder than the thumb.
Sometimes called a cushion valve:
1/2 NPT 3 GPM 5-15 PSI Hydraulic Cushion Valve | Prince Mfg | Brands | www.surpluscenter.com
I know my machine uses tank pressure to keep the flow of oil to the suction side of the pump. When the thumb reliefs back to the tank does that cause an imbalance in the tank pressure?
/ Pump Failure after thumb install #6
No, this would not cause any significant imbalance.
/ Pump Failure after thumb install #7
The pressure imbalance is in the supply side of the cylinder. Since it is moving without the oil pushing under pressure when the other side lets oil go, you are now creating a vacuum. Since the seals are made to keep oil in, not air out, the space fills with air. After a few cycles the air will work out again. So if you want to stop it from getting that "bouncy" feeling from the air in the system, the easiest place to get oil from is the other side of the cylinder, rather than sending all that oil to the tank. Similar idea to a regen circuit. Also, it means you no longer need a separate line to the tank from the dedicated relief valve on that circuit.
Does anyone have a picture of the cross over valve plumbed? I have a hard time understanding the drawings but not an actual picture.
/ Pump Failure after thumb install #10
This will not work on single rod cylinders due to the volume difference. I will try and sketch up a circuit tomorrow showing why you need the relief connected to tank
/ Pump Failure after thumb install #11
Is there a way to do both? I understand what you are saying with the rod end volume being different from the "plain" end...but without any make up oil, isn't the problem worse, you are comparing one end to nothing at all?
/ Pump Failure after thumb install #12
Yes you can do both. That is what I want to sketch up tomorrow
/ Pump Failure after thumb install #13
The attached generic schematic shows how the relief valve unloads the blind end of the cylinder to tank and how I would install the anti-cav check valve to help prevent cavitating the rod end.
Depending on the valve style used on the mini excavator you might be able to install the anti-cav check right in the valve. Some valves have the option for installing work port reliefs with anti-cav valves or just the anti-cav check only.
Hopefully this schematic is worth a thousand words.....
  • Thumb circuit.pdf
/ Pump Failure after thumb install #14
I don't claim to be a hydraulics expert so bear that in mind when reading my thoughts. Is your system open or closed center?
I also am not a believer in coincidences! There is a message in the failure of your pump and I believe you think so too. Pumps wear out from fluid contamination but this is a slow process. If your pump failed more dramatically, and you have not said how it failed, then it was being subjected to pressures beyond its design and safety factor levels.
When you use the phrase " mini excavator," are you referring to this equipment in your profile? Deutz Allis 5220 w FEL and Backhoe
Apart from the relief valve, the thumb cylinder is connected to a double acting control valve just as a FEL bucket cylinder would be. Am I understanding your description correctly?
If my assumption is correct, when the control valve is in the neutral position, oil is locked in within both the extend and retract hydraulic circuits by the open center control valve.
Your relief valve on the the extend side of the thumb cylinder is only dealing with one of two circuits with locked in hydraulic fluid.
Can you please post some pictures of your machine and also of the thumb, the control valve and relief valve.
Other posters may have solutions for you and I want to read them more thoroughly but clearly as you have done this installation, something is wrong.
Apart from the thumb installation is the hydraulic circuit just as it left the factory or have valves been changes etc.
Dave M7040
This is any IHI mini Excavator. The spare valve on the block did not have a relief. I was afraid of bending a rod so I put a relief in it. On the manifold (the part with 14 spools) I ran a Hose to a relief. Hose - Relief - to cylinder. The relief then has a hose on it witch goes back to the main tank. When you over power the thumb with the bucket it opens the relief and pushes the fluid back to the tank. The cylinder would act bouncy till it cycled. Now I know I had the pressure set very low on the thumb relief 1500lbs vs 3000 system pressure. When It was overpowered I mean only few inches. Its a closed system. My own thought would be the pump was cavitating and its so noisy in the cab I didn't know.
2023 John Deere X590 Lawn Mower (A63116)
2023 John Deere...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
17601CFL (A59228)
17601CFL (A59228)
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
40ft Shipping Container (A64194)
40ft Shipping...
