Pulverizer
   / Pulverizer
thanks for the complements guys. the roller was actually 2 sections of 6" sch 80 pipe that I found in the scrap yard. Cut them to length then welded the to pecises together to make it about 5' 10". then I cut out the end plates from 3/8 plate and put the 1" solid shaft through it. But the shaft is not full lenght because that would cause it to bow in the middle so instead I made two parts for that look like this l----l- and they slide into each end. As far as the spikes on the roller they are 1/2 " round by 1 1/2" long. They are spaced 3" apart and are 8 around making for 192 very tedious welds.
   / Pulverizer #13
That's some nice welding - and a lot of it too!
Did you fill the pipe to make it heavier or is it heavy enough as is?
jb
   / Pulverizer
I thought about filling the pipe with something but it weights around 100-120 now so the should be enough, although I would like to get some heavier springs to give it more down preasure.
   / Pulverizer #15
Looks like a good building job to me. I've seen pulverizors on skid steers that had two rollers. But I guess you don't want to make all those extra welds for a second roller!
I've been to PEI and fondly remember "fries with the works". The works of course being the peas and such. Beautiful place.
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2012 Ford F-550 (A55973)
2012 Ford F-550...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
