pulling up T-posts w/ hyd.
/ pulling up T-posts w/ hyd. #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
Is it ok/not harmful to use hyd. lift and drawbar w/ chain to pull t-posts up out of the ground?
/ pulling up T-posts w/ hyd. #2
I dont see any problem with it. I would just center them on your bar, and pull, I have used the front end loader to pull them. Metal posts are not usually that hard to pull
James K0UA
/ pulling up T-posts w/ hyd. #3
3 Pts and FEL's work great for pulling fence posts out of the ground, and FEL's also work great for pushing them in the ground. Just wrap the chain around it a couple times so it doesn't slip off. :thumbsup:
/ pulling up T-posts w/ hyd. #4
It works a lot better and safer if you drain out the tractor's hydraulic fluid and replace it with water. As you all know, water is incompressable so this conversion to hydrolic action will keep your tractor from getting away from you. Of course, the recommended way is to break them off at ground level and then fill your tires with foam or Slime so the post stub won't flatten them. Then throw the broke-off part of the post over the fence so your neighbors mower will hit it. That can sure be a lot of fun to watch.
A real man would just pound the posts down into the ground with his fists and be done with it. No tractor required. Be sure to save the old fluid because it makes for a good fuel when roasting them baby backs on the burn barrel.
Of course, this being the first of April, you don't have a lot of time to get this all done before the ground hardens up and the price of new posts goes threw the roof.:D
thanks, no fel so lift it is...although zz's got some good ideas too
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
2012 Addco DH250-FM Towable Solar Message Board (A64553)
2012 Addco...
