Pulling trailer with dozer
/ Pulling trailer with dozer #21
You guys sure like to complicate thinks!
NONE of my trailers know if it's a truck, tractor or dozer in front of them...
Buy the PROPER ball, install it on the dozer draw bar, and pull the trailer!
SR
And that is how simple it is!
/ Pulling trailer with dozer #22
Actually, I just discovered they don't come any longer than 10' which is not enough for 3 ATVs.
I've been looking around and can't find a 14' dump with removable or folding down sides.
Anyone?
PJ's deckover dump trailers have fold down sides:
84" wide: PJ Trailers | 84" Deckover Dump
96" wide: PJ Trailers | 96" Deckover Dump
As do the ones by BigTex:
14OD/14OD-GN Tandem Over The Axle Dump | Big Tex Trailers
As for the dozer question, if you need to switch back and forth often. I would get a 1.5-2' long piece of heavy wall (3/8" or 1/2") box tube that just fits inside the hitch, make a 2" deep notch for the center rib of the hitch, punch 2 holes for the pin and one for the ball.
Then when you need to use the ball, you slide the hitch over the center rib, drop the pin in and off you go.
That will also push your trailer back from the dozer a little and let you turn sharper.
Aaron Z
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
Bobcat T62 Compact Track Loader Skid Steer (A64553)
Bobcat T62 Compact...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2008 International 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2008 International...
