Pulling trailer with dozer
/ Pulling trailer with dozer #21
You guys sure like to complicate thinks!
NONE of my trailers know if it's a truck, tractor or dozer in front of them...
Buy the PROPER ball, install it on the dozer draw bar, and pull the trailer!
SR
And that is how simple it is!
/ Pulling trailer with dozer #22
Actually, I just discovered they don't come any longer than 10' which is not enough for 3 ATVs.
I've been looking around and can't find a 14' dump with removable or folding down sides.
Anyone?
PJ's deckover dump trailers have fold down sides:
84" wide: PJ Trailers | 84" Deckover Dump
96" wide: PJ Trailers | 96" Deckover Dump
As do the ones by BigTex:
14OD/14OD-GN Tandem Over The Axle Dump | Big Tex Trailers
As for the dozer question, if you need to switch back and forth often. I would get a 1.5-2' long piece of heavy wall (3/8" or 1/2") box tube that just fits inside the hitch, make a 2" deep notch for the center rib of the hitch, punch 2 holes for the pin and one for the ball.
Then when you need to use the ball, you slide the hitch over the center rib, drop the pin in and off you go.
That will also push your trailer back from the dozer a little and let you turn sharper.
Aaron Z
Clubcar (A64557)
Clubcar (A64557)
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
MOWER MAX SLOPE MOWER (A63276)
MOWER MAX SLOPE...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A64556)
2015 Hyundai...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
