Pulling stuck vehicles out of the ditch with a tractor
   / Pulling stuck vehicles out of the ditch with a tractor #21
I still pull many people out when I come across them depending on their attitude and the circumstance's. I do not normally connect to their vehicle, let them do it, I might make a suggestion if so inclined. I have seen several instances were the rim and tire is the preferred tow point on many vehicles, using a flat strap through the rim.
   / Pulling stuck vehicles out of the ditch with a tractor #22
I’ve had good luck pulling out vehicles that were significantly heavier than my tractor, using 1/2” wire rope and a snatch block pulley. I hook one end of the rope to a tree (or other fixed object) near my tractor and hook snatch block/pulley to the front of the stuck vehicle. Run the other end of the rope around the pulley and back to my tractor’s drawbar.
The tractor moves twice as far as the stuck vehicle and the pull force exerted by it is doubled, which enables you to extract a vehicle that is nearly double the weight of your tractor.
A little momentum gives you an added “boost”, (when they are really stuck good). If you just need a slight added boost after your wheels loose traction, dropping the front loader bucket straight down, lifting the tractor front slightly, and curling the bucket down, will give it to you. That’s not as effective as a little slacking of the cable, and jerking it tight again, though.
You can use those same (loader pull and slack cable/jerk) methods without the snatch block and pulley but the strain you put on your tractor will be doubled and you will be more likely to damage it. The only rigging gear you got to worry about with the snatch block is what’s between it and the stuck vehicle (that’s where you want your strongest chain, etc.).
I admire your desire to be a God Sam, but remember: "No good deed goes unpunished."
The safest advice is the title of another thread, "Don't Do It" for the reasons bcp stated.
You did state you have experience recovering using a Jeep and winch and even dynamic recovery straps, but your question about weight indicates limited experience. The force to recover a vehicle may be a fraction of or a multiple of the vehicle's weight depending on the situation. Procede cautiously and deliberately.
The Jeep (with the winch) was my wife's, but she traded it in on a Tesla (not a lot of ground clearance) so I should as least figure out a recovery point on that or I'll be in trouble lol! But it's mostly body on frame vehicles around here so I'm not too worried about damaging them.
If the stuck vehicle is heavy or in a precarious situation, I will just leave it to the experts. I'm not trying to be a hero with this, I just want to keep my road open and make sure no one is in danger.
   / Pulling stuck vehicles out of the ditch with a tractor #24
Just watch to not rub your chain, tow strap or Bubba rope on the blade edge of the back blade while under tension.
I have a link on one of my chains that is compromised because of this when pulling over a tree that I anchored up high for leverage to pull the root ball out with the tree.
The chain was rubbing on the blade edge during the pull...and the blade won.
   / Pulling stuck vehicles out of the ditch with a tractor #25
At my old place the neighbors girl friend got stuck in the snow drift the town plow had put across their driveway.
A couple of us saw this from my place so we walked over to see what was going on.
She needed a small push to get over the drift.
Tried to sue us all for the damage to her brake lines and steering alignment. Also one or more of us was responsible for putting a big dent in her trunk lid. It had obviously been there sometime and had rusted where the paint was missing.
I'll call the local tow truck if you want.
Push/pull no way.
   / Pulling stuck vehicles out of the ditch with a tractor #26
Then there is the time you are trying to be a nice guy and help the two local rednecks with a Ford Duely really stuck in a bog and his buddy is big 4WD Chevy.... The didn't have much and was needing help (would not take my 4WD Jeep into bog) but loaned then a 30 ft 5/16 chain..... First thing they did was hook up chain with about 10 ft of slack and Chevy guy took a full power run to jerk his buddy out of bog.... Well it didn't go well, they manage to break chain and strech many links to a point where it was no longer reliable......When the mud settled all I had was a damaged chain and a "sorry man"..... They promised me a new chain, but it never happened..... Sometimes it may be better to just go on by and get home, settle in by the fire and wait for knock on door and them asking to use the phone....
   / Pulling stuck vehicles out of the ditch with a tractor #27
I've been fortunate, many cars and trucks, (even a UPS truck) pulled out of the ditch/snow/mud and I've never had a problem. I know it only takes one sob to turn you into a cynic. I always tell them it's their job to hook up the tow strap. I do my best to be a good neighbor.
   / Pulling stuck vehicles out of the ditch with a tractor #28
My only comment is, in today's liability prone society, I prefer to let them reside in the ditch and call a professional recovery service to extract them. Pulling a vehicle out of the ditch can be an exercise in getting sued for damage, or worse.
I used to do it, but no more.
   / Pulling stuck vehicles out of the ditch with a tractor #29
On many tractors the engine, transmission and rear axle casting are the only frame and its not appropriate to hitch at non-designed towing points.
More than one person has broken tractor castings by pulling at the wrong point.
Basically tow from somewhere the factory designed for pulling from.
   / Pulling stuck vehicles out of the ditch with a tractor #30
With winter coming up I'm sure someone is going to go off my road, into the ditch, and get stuck. I used to recover using a Jeep with a winch, but it I no longer own it. My tractor has a hitch, but my rear blade is most likely going to be in the way. So where's the best place to attach a shackle to the front of the tractor? Also, my tractor, with the rear blade attached is about 10,500lbs, what's the heaviest vehicle I should be trying to recover? Any other tips for using a tractor to recover stuck vehicles (this is my first tractor)?
My tractor weighs around 5,000 lbs. including the FEL and box blade. So, half the size of yours. A couple winters ago my step son slid his Toyota Camry off the road in the snow and hit a tree. I drove my tractor down to the accident scene about 1.5 mile and hooked a fabric strap around a rear wheel. Used the FEL to lift the car slightly and pull it up onto the roadway and set it back down again. Worked great and prevented additional damage to the car.
A tractor with a 10k lb. working weight should be able to pull any vehicle easily.
Rhino HB78 78in Box Blade Tractor Attachment (A55973)
Rhino HB78 78in...
2021 Chevrolet Silverado 1500 Pickup Truck (A56858)
2021 Chevrolet...
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
2005 Toyota 7FGU35 8,000lb. Straight Mast Propane Forklift (A55973)
2005 Toyota 7FGU35...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
2003 Big Tex 10PI...
