pulling force of a B2920
   / pulling force of a B2920 #1
tractchores
Ma
Kubota b2920
I was wondering if anyone ever estimated the pulling force of their tractor. I'm trying to size some rope / chain / cable for pulling trees (i.e. putting pressure on them as they are cut to get them to fall in the right direction). I have 5/16" chain now, which is labelled as having a working load of 4,700 lbs. I pulled on a tree on a level surface with great traction (paved and I have loaded turf tires) and spun all 4 wheels without breaking or stretching the chain. The shock load of going forward and being stopped by the chain also did not effect the chain. I"m not sure if my chain has a max load of 4700 lbs or something greater.
I'd like to get a chain / cable / rope that is far greater than the pulling strength of the tractor so that I cannot break it and create a dangerous situation. Anyone have any ideas what the largest pulling force a tractor of this size can apply is?
   / pulling force of a B2920 #2
I'm no tree expert, but.......it's my understanding that a rope...cable...chain etc. is used to simply guide the fall of the tree; not literally pull it down. A chain long enough to do the job would be too heavy in my estimation. I use 3/4 inch nylon rope that has a "work load limit" of 1,420 lbs. I've had no rope failures using my F-250 as the power source. On some ocassions I use the bucket of the B2620 to push an easy one over. I doubt that a B2920 could break any decent size rope..cable or 5/16chain....:2cents:
   / pulling force of a B2920 #4
Most chains are underrated for wear and abuse. 4700 pounds "work load limit" basically means with 4700 pounds hanging, it will never stretch or break. The actual point that it will stretch or break would be significantly higher depending on the type of force put on the chain (jerking, binding, etc.). A chain made to work with 4700 pounds of weight would likely take up to 6000 pounds of hanging weight before any stretching occurs, and a break weight would likely be closer to 10k. I've seen what it takes to stretch an old "unrated" 5/16" chain, and 10k isn't even touching it...
Before the safety police jump in, none of this is any sort of recommendation to overload a chain or anything else; my point is only that "working weight ratings" are underrated to allow for the typical wear and uses for such things.
I would agree that a B2920 will never break a 4700# rated chain without adding a lot of weight to the tractor. At 30ish horsepower, I think there is the power to break such a chain, but at 1500ish pounds, it'll never put enough of that power on the ground...
Thanks, that is an eye opening link to the strength, i had no idea breaking force was 18k lbs. i'm looking to get some rope so i can use pulleys, i was looking at 8,000 lb breaking strength on that. Think that will be a safe enough margin?
   / pulling force of a B2920 #6
My 12K# 7520 setup will stretch a 5/16 Grade 43 chain but will not stretch the Gr70 - which is the one rated for 4700 working load. This is steady pull w/o intentional jerking. Inevitable jerks are what the ~ 4X breaking strength safety factor covers.
larry
   / pulling force of a B2920 #7
Remember, you do NOT want to pull hard on a tree that is being cut. As stated above, you want to GUIDE it. Pulling too hard could create a very dangerous situation for the person behind the saw. Effectively making the tree into. to a "leaner" which could barber chair on the cutter.
   / pulling force of a B2920 #8
My memory seem to recall that the safe working load of chain is typically about 1/4 of its breaking strength.
But being a boater, I've used 150' anchor ropes and a come-along to pull trees in the direction I want them to fall. Leaning an extension ladder up against a tree can get you high enough to apply some real good leverage without needing tons of force. Using my tractor as the anchor point also allows me to stretch the ropes before tugging any with a come along. If I need more pull I can walk over to the tractor and work the come along without even putting the saw down, all while staying out of the tree's fall path.
   / pulling force of a B2920 #9
If your not jerking the chain just a dead pull then you could guesstimate your tractive effort on level ground by knowing the operating weight and mu level Ag tires have about 0.7 mu on hard pack or gravel. Meaning if your rig weighs 4000 lbs you can only pull about 4000 lbs .7 = 2800 lbs is the maximum cable tension you could hope to sustain. However if your jerking it loads go through the roof and i would switch to a snatch strap. As you don't want to be on the receiving end of a broken chain or cable
Thanks. In pulling configuration the machine is probably 3500 lbs, the BH almost doubles the weight. I usually tense it up, make a partial cut then pull to get the tree to pivot on the hinge if it's a bad leaner then make the final cut when it's leaning the right way. It does load the tree a bit, so safe positioning is huge.
The biggest forces will be from skidding or from pulling a leaner's butt end out to get it on the ground.
PEDESTAL FAN (A58374)
Pines 1400 Tubing Pipe Structural Bender (A59213)
Pines 1400 Tubing...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
1982 FIAT-ALLIS FR10 WHEEL LOADER (A52708)
1982 FIAT-ALLIS...
2017 Bobcat T770 Compact Track Loader (A56435)
2017 Bobcat T770...
