pulling bearing race out of roller tube for hesston bailer
   / pulling bearing race out of roller tube for hesston bailer #1
kioskcarp
tn
john deere 5075e cab with 553 fel
Need help. How do I pull a bearing out of a roller tube on my 530 hesston bailer? I dont have a bearing tool. Is there any other way?
   / pulling bearing race out of roller tube for hesston bailer #2
You can weld a bead around the inside of the race & it will shrink it some.
   / pulling bearing race out of roller tube for hesston bailer #3
Socket or pipe with a diameter just snaller than the ID of the tube the bearing is in.
   / pulling bearing race out of roller tube for hesston bailer #4
Ditto on welding bead around center of race to shrink it.
   / pulling bearing race out of roller tube for hesston bailer #5
to make a puller ....
a long steel pipe thinner than the bearing race ....
a bigger shorter pipe that just slips over the smaller pipe
an end cap for the smaller pipe ...
a grade 8 nut and bolt just longer than the pipe is wide
drill a hole across the end of the pipe , slip the bolt through and put the nut on......
now put the nut/ bolt end down , slide the shorter larger diameter pipe on to the smaller pipe , then screw on the end cap to the smaller pipe
slide the small pipe into and hook the nut or bolt behind the race lip ....
you now have a slide hammer to pull the bearing race ... tap a few times , move the but/bolt to the opposite side of the bearing and tap and repeat .. do not try to pull it out from just one side , the race will twist and jam ....
2008 KAWASAKI MULE 3010 UTV (A58375)
2008 KAWASAKI MULE...
72in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
72in Dual Cylinder...
2001 MACK RD688S WATER TRUCK (A58214)
2001 MACK RD688S...
2372 (A58376)
2372 (A58376)
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2009 Utility Trailer Mfr. 4000DX 53ft. T/A Dry Van Trailer (A56858)
2009 Utility...
