Pulling a trailer with your tractor
/ Pulling a trailer with your tractor #81
Where are folks finding the tow rating for their tractors and the max tongue weight for the drawbar? I can't find anything for my NH TC33D in the owner's manual, and a search online has not turned up anything yet.
Mine is on the identification plate in the tractor and on the title. The drawbar rating is on the drawbar it self but don't have a good enough picture of it.
/ Pulling a trailer with your tractor #82
My 18’ equipment trailer empty weighs 2500 pounds and I have pulled it with my IH 424.
The empty trailer can push the tractor around on hills even with the tractor brakes applied.
/ Pulling a trailer with your tractor #83
I've moved my dozer to jobs many times with my tractor,
but more often I'm moving loads of firewood,
And sometimes I even head home with "grapple load" on the pallet forks too,
Most times with a tractor, it isn't, "will it" do it, it's "should you" do it...
SR
Did some work on a diesel 7.3 one ton Ford long box 4x4 one spring that would not start. It had rained for weeks. hooked on in 2 wheel drive 1st gear and forgot the Ford was in gear . Pulled it to the garage and turned around to look there was a foot of mud pushed up in front of all four tires on the Ford, the tractor never spun a tire.
Wish I could find the factory engine driven Air compressor and tank trailer brake kit for the Rhino tractors, would be handy to have.
/ Pulling a trailer with your tractor #84
Yep.
Many trees I have put a long line on them on top of a ladder that were leaners and put tension on with the tractor ,then shallow hinge cut and pulled them over against the lean. including this/these.
Probably should have hired it out.
Research On Board Air (OBA) in the Jeep type forums. They have used AC compressors to make belt driven air compressors.
I built one and it has enough CFM to run a framing nailer and was very handy when we were building fence.
I want a OBA setup for my TC45DA. I just need to find a salvage TC with a factory cab and get the HVAC compressor and it’s mounting brackets and pulleys to make it.
I could make the brackets but factory stuff is easier and less likely to have alignment issues.
/ Pulling a trailer with your tractor #85
I did the York factory AC compressor on my old J10 Jeep used a standard 120 ish pressure switch to the clutch and a 10 gallon tank Pumped air faster than my 5 HP IR 60 gallon unit
This factory option was neat, Pump is mounted to the front engine gear cover.
Never been able to find the pump on aliexpress or alibaba, I keep checking from time to time though. It has a run no run lever, and is driven off of the Injection Pump's gear.
/ Pulling a trailer with your tractor #86
Be careful with a rear axle(s) only trailer and using the three point instead of the fixed drawbar. It doesn't take much upward pressure on the tongue to overpower the control arms, and you'll drag the rear of the trailer or your load. More tongue weight than you'd have with a bumper hitch helps avoid that.
/ Pulling a trailer with your tractor #87
My Massey 7495 has an air compressor mounted to the diesel engine, just like a typical air-braked truck, and trailer air brakes.
/ Pulling a trailer with your tractor #88
I use a 3pt trailer mover on my BX2200 to move my 10000# double axle utility trailer. When I was creating my new patio a few years ago, I had the trailer loaded up with 2 pallets of concrete mix and I needed to get the trailer in a tight space to save my back a little more, so I used the tractor. Plopped it in 4x4 and L, and it handled it just fine. Just took it easy, but it had no issues nor did it feel unstable at any point. I had to be at full weight on the trailer around 9000#. Granted I only moved it a couple hundred feet. But I was pleasantly surprised as to how well the machine moved it.
1259 hrs (A61574)
1259 hrs (A61574)
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
FORKLIFT (A56857)
FORKLIFT (A56857)
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
