Pulling a trailer with a compact tractor
   / Pulling a trailer with a compact tractor #11
I use a 6'' by 2.5 " 1/4" thick steel bar that I put a trailer ball on 1 end and drilled a hole in the other end so i can bolt it to either my BOLENS garden tractor or my Wards lawn tractor hitch to move my utility trailer around. With this gadget I don't need to use the BX 23 to move the trailer.
Only have 8 bucks in this gadget and that was for the ball!
   / Pulling a trailer with a compact tractor #12
on my bx-22 i mounted a frame class IV hitch from my old truck into my bucket.
drilled four holes and i can slip it in and out real quick. (my wife likes that).
if i need to cover the holes a piece of duct tape suffices.
i move my wood chipper,car carrier,3 small utility trailer's around all the time and did not want to bother removing the backhoe all the time.
then i can change to a pintle hitch,2",1 7/8 or whatever real quick just like on my truck.
i realize you do not have a backhoe and the weight up front may be an issue for you.
but it works out great for me just around my small 3 acres.
good luck
scott
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
