Pulling a steering wheel
   / Pulling a steering wheel #1
Archie87
1961 Massey Fergason/ Industial
Hi, I'm new to tractor ownership, I have a 1961 MF30 Industrial, and am trying to pull the steering wheel, i have tried a puller but it keeps slipping off do to the bevel on the underside off the wheel? any suggestions?
   / Pulling a steering wheel #2
My steering wheel hub and nut are pretty well rusted. I'll be removing my steering wheel soon, as well. I am soaking the center hub with PB Blaster which I have used extensively to free up other rusted stuff my M-F 231S.
After a nice, long soak, I would remove the nut and carefully tap the center shaft while putting some upward pressure on the wheel. Hope you get it off. Use care when hammering on the shaft.
Some heat may help, as well. I have a heat lamp I use for stubborn stuff like your wheel.
Once off, I'm going to fill the cracks in the wheel and spokes with epoxy, paint the wheel then sew a leather wheel cover onto the wheel.
Let us know how you fare.
   / Pulling a steering wheel #3
a few links of chain with a bolt around each spoke , hook your puller in the chain
   / Pulling a steering wheel #4
Loosen the nut but don't take it off all the way. Leave a few threads between the nut and the steering wheel. Stand on the floor boards and pull up on the steering wheel as hard as you can while alternating which arm pulls harder. Be aggressive. It'll come off...very suddenly. That's why you leave the nut on the shaft.
Same as above but just get someone to pull on the wheel. This time leave the nut flush with the top of the shaft. Take a brass shaft about an inch in diameter and six inches long. Place it on the top of the nut and hit the brass with a hammer as hard as you can. In about two hits it should come off. The person pulling up on the wheel should pull as hard as they can.
Have fun and good luck!
   / Pulling a steering wheel #5
I take it that it doesn't have the threaded holes on each side of the center hole, perhaps you could get behind it with a large bearing puller,
   / Pulling a steering wheel #6
I needed to remove the wheel from a project side by side that didn't have any puller accommodations. I used some 2 x 4s, c-clamps and all thread. The all thread has a nut and washer behind the 2 x 4 that is not visible (jpg attached I hope). Clamped it all up and then loaded up some tension (cautiously) on the rod nut, a couple whacks on the rod with a hammer then more tension. Repeat as needed until the taper released. It helps that the tension is constantly applied, yours may need some penetrating oil as previously suggested. IMG_6288.JPGIMG_6288.JPG
Steve
   / Pulling a steering wheel #7
PB Blaster is not the best.
Use Kroil, and let it sit for up to a week, applying periodically.
   / Pulling a steering wheel #8
I've yanked off several steering wheels. As I get older I look harder for a mechanical way to apply pulling pressure.
You've been shown a couple methods that will allow you to use mechanical force.
You can dunk your tractor in a large vat of PB Blaster or whatever your favorite is and it won't do any good.
   / Pulling a steering wheel #9
I disagree.....and I am "older"!
I kept the nut cavity filled with Kroil for a week.
Gently used an impact wrench, hammering the nut tight, then loose, every other day.
Just a little up tap with my hands, and the wheel popped off.
   / Pulling a steering wheel #10
Good idea!
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
23169 (A50324)
23169 (A50324)
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
