Pulling a Lime Spreader with 2210 D
/ Pulling a Lime Spreader with 2210 D #1
rgood
SW Iowa
John Deere 3020
Guys - The Coop nolonger will spread lime - However, they will rent a buggy/spreader to me. The spreader holds 4 Ton of lime and the spreader weighs about 3,000 pounds - And it has pretty large tires. Will a Yanmar 2210D pull that over sand? The terrain is perfectly Flat - I have a loader/bucket I can fill with sand for front end weight. But obviously the buggy is outweighing the tractor by quite a bit.
I can pull it my Ford F-250 but the pickup needs a country mile to turn around in.
Hi, just trying to bounce this question to the top - Thanks!
Well, Didn't get a chance to try it yet - Accuweather said no rain til 3 pm - They Lied. I did get a look at the buggy though and the tires are pretty large.
/ Pulling a Lime Spreader with 2210 D #4
RGood,
My wife and I rented the Lime Spreader (from Washington County Co-op) and towed it with our F-250 Diesel. We did not have a tractor at the time so, we used her truck. The spreader did a good job of reaching the the parts where turning around was a problem.
Next time, we will test with our John Deere 790 (Green Yanmar). It is 27hp.
Won't anytime soon as our pastures are still soaked from that last rain.
Sincerely,
Ikymojoe
IKY - Thanks for the info - I did end up using my pickup to do the job - And I did hit a couple wet spots where the wagon sunk - I was glad I was using the pickup at that time instead of the tractor - I wouldn't recommend the tractor for the job - especially if you have areas where trees have been removed as the ground may be soft in those areas.
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Mack Pinnacle...
iDrive TDS-2010H...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A61574)
2013 29ft. Larson...
