Pullin Old Fence Posts
   / Pullin Old Fence Posts #1
digicamnut
South East Teaxs
What is the best way to get Old metal Fence Posts outa the ground? I got to get about 15 out real soon. I there an attachment out there?
   / Pullin Old Fence Posts #2
I wrap a chain around the post and the loader or around the post and backhoe and lift them out.
The stubborns ones i had to dig out with the BH.
   / Pullin Old Fence Posts #3
What LBrown59 said. I put one end of the chain in the bucket hook and wrap the other end around the post. Most come out very easy.
   / Pullin Old Fence Posts #4
...and curl the bucket to pull them, it adds mechanical advantage to the lifting/pulling.
   / Pullin Old Fence Posts #5
If they're stubburn, tap 'em a couple of times with your bucket about 2/3 of the way up.
   / Pullin Old Fence Posts #6
i made up a lenght of chain with a small loop on the end i slip down over the post. Snatch with curl.
ive pulled 30-40 this way
   / Pullin Old Fence Posts #8
Not sure what type of equipment you have available but this is what I use....
dsb
   / Pullin Old Fence Posts #9
I welded a ring of pipe to a chain to make a puller. It works OK with the FEL and is a tad faster to use than wrapping a chain. For tough ones I lower the bucket and use curl to avoid picking the rear wheels up, even if my HD box blade or mower is on the 3PH.
For really tough ones you have to push on the post a bit from a couple directions (like wiggling a baby tooth prior to pulling.)
I also have a post popper (like a jack) for pulling posts manually where a tractor won't fit.
Pat
   / Pullin Old Fence Posts #10
I do that by hand on all posts before I pull them. It makes them come out with 1/3 the effort...
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2013 Nissan Pathfinder SUV (A50324)
2013 Nissan...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
