pulleys and sheaves
/ pulleys and sheaves #1
wowbw7
Bronze Member
2 questions I hope someone can help me with:
1) almost all the v-belt pulleys or sheaves I find are listed as "fractional horsepower" rated. to me that sounds like you can only use on equipment with less than 1 horsepower, but I know that can't be true. what does the fractional horsepower rating mean?
2) i have had to remove pulleys from shafts many times where space behind the pulley is tight and using a puller is sometimes quite difficult or impossible to use. my question is: is it a good or bad idea to coat a shaft with anti-seize before installing the pulley to ease in removal?
thanks for any help
/ pulleys and sheaves #2
I cant answer #1 but in reply to anti seizing a shaft, this is something i've always done with no ill effects. Either anti seize or white lithium grease. somewhere down the road you or someone else will surely be thankful.
/ pulleys and sheaves #3
A fractional horsepower motor (FHP) is an electric motor with a rated output power of 746 Watts or less.
....according to Wikipedia anyway.
/ pulleys and sheaves #4
Sizing info:
McMaster-Carr
Also check pages 1036-1039
At different speeds they can handle various HP ratings. Strangely enough, running them faster gives them a higher rating. Also you can gang them for higher HP too.
This chart is for multi rib belts (like current fan belts in cars) but it illustrates the point:
Also, yes, use a high temp wheel bearing grease.
  • Page191_from_GatesDriveDesign.pdf
/ pulleys and sheaves #5
some more info:
  • PagesfromGatesDriveDesign_8-12.pdf
  • PagesfromGatesDriveDesign_15.pdf
/ pulleys and sheaves #6
the use of never sieze is a must when dealing with such things
/ pulleys and sheaves #7
Since HP is calculated in the time it takes to do work, it isn't a surprise to find speed ratings on the hp requirements on sheaves.
David from jax
/ pulleys and sheaves #8
I do not know where you are looking but any good PT house will have what you need.
