Pulley / PTO Shaft
/ Pulley / PTO Shaft #1
alvanko
Hinckley , Ohio
Yanmar YM186D & Ford LGT14D Dixon Z BX2200D Kubota
I am in need of a pully for an old chipper I have.
Pulley is 16" diameter with a 1" center hole and 1/4" key way. 5/8" v-belt. I have searched ww grainger and the closest I can find is 14". Mine is steel. Would like to keep the same or cast, would like to stay away from aluminum. It needs to have set screws.
I am also in need of a PTO shaft or half of a PTO shaft. 27" (approx) overall. 1" round center in the yoke with 1/4" key way, standard 1 3/8" 6 spline on the other end.
I have half of a shaft that is hollow triangular tubing approximately 1" diameter with the 1" round yoke with key way. I would need the other end that slips over this with the 1 3/8" six spline yoke.
Any sources I can search?
/ Pulley / PTO Shaft #2
I'd go to your local power transmission house (Motion Industries, Dixie Bearing) They can fix you up with a Browning or Dodge. It looks like there are about 12 located in Ohio
CAT CB34 (A60462)
CAT CB34 (A60462)
TEREX LIGHT TOWER (A63569)
TEREX LIGHT TOWER...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
BOB TAIL KILL TANK (A63569)
BOB TAIL KILL TANK...
