pulley driven cordsaw
/ pulley driven cordsaw #1
cbailey1956
Bedford, VA
Allis Chalmers B, Komatsu D31, Case 585
Hello fellow members. I have had this old cordsaw sitting around for over 10 years. Never used one but came across this one with good bearing and frame so here it sits. I was wondering how fast they should turn. Thinking about converting it to a hydraulic drive and placing it alongside by processor to handle the small stuff. Have plenty of hydraulics just curious how fast to operate it at. Thanks for looking. CraigView attachment 445131
/ pulley driven cordsaw #2
They turn pretty slow especially since it appears to have Babbitt bearings.
/ pulley driven cordsaw #3
Rpms needed is determined by the dia of the saw. I believe Cooks Saw Mfg has specs for saw speed. You might have to search their site for the info.
/ pulley driven cordsaw #5
Interested in this build. Hand only owned one. Was thrown in the deal when I bought a tractor after the tractor was loaded the guy told me to take it. Then I got rid of it 2 weeks later.
I don't know much about them so I'm interested in this. I would thing its needs to be lower rpm because of the size of blade
/ pulley driven cordsaw #6
I have two of them, you don't have to run them very fast, but I agree with running them off the PTO is better than hydraulics...
SR
/ pulley driven cordsaw #7
Belt pulleys I believe run about 1200 RPM.
PTO drive is probably a good way but not necessarily easier for me. I have the hydraulic power existing in my processor and this will be set up near it. Thinking a hyd wheel motor driving a bearing block supported shaft with pulleys and belt setup to drive the cordsaw pulley. Just really don't want to rely on hooking up a tractor to the saw. Just want to get the rpm close to start with and then can flow adjust speed. as needed. Was thinking around 900 rpm myself for that blade.
/ pulley driven cordsaw #9
Well, I never run my tractor anywhere near pto speed, when I'm running one of my buzz rigs...
SR
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A66736)
2017 Volvo VNL T/A...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
2016 JCB 3CX 4x4 Loader Backhoe (A68183)
2016 JCB 3CX 4x4...
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
3143 (A63117)
3143 (A63117)
