Pulled the trigger today on a Duramax
   / Pulled the trigger today on a Duramax #101
Dang, I've got to go to Indiana an pick up a square baler if it works out in a couple of weeks. Think I will throw in my aux. fuel tank in the back of the truck and fill her up before I leave home! LUTT
   / Pulled the trigger today on a Duramax #102
   / Pulled the trigger today on a Duramax #103
By the way handirifle, congrats on the purchase. Those are good trucks. Pretty much the best Dmax was 06 and o7 classic! I looked for one before I purchased a 14', I had my mind set on a black or silver 06 but couldn't find the miles I was looking for. I'm pretty tickled with the fuel mileage on it towing and empty, but only have 5000 miles on it, time will tell. I've had twenty empty on the interstate at 65 and low as 14 around town and towing on the interstate. LUTT
   / Pulled the trigger today on a Duramax #104
That is a really nice truck and I hope that you get great service out of it...
Just a few thoughts...
1. Here in NC the sales tax is 3%...
That would be around $855 for your purchased price...
2. The price you paid is what it would go for around here, perhaps a tick more...
Diesel 3/4 and 1 tons are still in high demand around here...
3. I just purchased a cheap clean 1 owner commuter car to keep the miles down on my F350...
The truck is paid for, has 110K miles, and is a pre EPA crap fest 03 model with the 7.3 Powerstroke...
I ain't selling it...
To me being paid for is worth more than I could get out of it...
   / Pulled the trigger today on a Duramax #105
Then why do all the manufactures rate the gas options with less payload and less of a tow rating. When it comes to pulling the gas options are better than they have ever been that is true but they can not compete with the diesel option. Work a truck to or near it's rated limits day in and day out the diesel will hold up better than the gas. One of the reasons for this is that the diesel does not have to work as hard to do the same job.
So a 400HP diesel making 200HP pulling a trailer up a grade doesn't work as hard as a 400HP gasser making 200HP pulling a trailer up a grade?
Use some facts instead of subjective deviations.
How does "working as hard" even matter? It's a light highway vehicle, not a 24/7 genset running 24/7 at rated output? How can so many people not be able to understand a 400HP pickup spends most of it's duty making 40-50HP cruising or idling at the 7-11 while the owner in in for a pack of smokes.
   / Pulled the trigger today on a Duramax #106
NEVER having the truck downshift while climbing that 3 mile grade is a very pleasant surprise. Really the engine doesn't even sound like it's working. My Tundra would have downshifted from overdrive and have to hold 3000+ rpm to maintain 65 or so up that same grade.
Is it a crisis that the transmission downshifts and the engine revs up to climb the hill ?
Does anybody really think that is going to "blowup" the engine or wear it out and need a rebuilt before 75,000 miles?
   / Pulled the trigger today on a Duramax #107
Around here the 2003's have rust holes through the tailgates , fenders and rocker panels. Some have already been scrapped due to corrosion.
We are stuck driving late model EPA vehicles around here.
   / Pulled the trigger today on a Duramax #108
So a 400HP diesel making 200HP pulling a trailer up a grade doesn't work as hard as a 400HP gasser making 200HP pulling a trailer up a grade? Use some facts instead of subjective deviations. How does "working as hard" even matter? It's a light highway vehicle, not a 24/7 genset running 24/7 at rated output? How can so many people not be able to understand a 400HP pickup spends most of it's duty making 40-50HP cruising or idling at the 7-11 while the owner in in for a pack of smokes.
1. Never smoked a day in my life.
2. I did use facts you can not get a gasser rated near as high as a diesel equipped truck for towing.
3. It's not hp that pulls the load it's torque.
4. A diesel doesn't rev half as high as today's gas engines so yes same work running half as hard.
5. I use my trucks hard I've got much more reliability out if the diesel equipped trucks than I have the gas equipped.
   / Pulled the trigger today on a Duramax #109
I understand your situation...
Here in the south rust is not as big of an issue...
   / Pulled the trigger today on a Duramax #110
7-11 for a super sized slurpy, a coffee or what ever. So everybody can listen to your diesel idle.
For those who don't have a credit in basic high school physics. Torque alone does not do work. Rpm does not perform work. Time does not perform work. It takes torque and rpm together to perform work. It's a calculation of torque and rpm with relation to time to raise a load against gravity and assorted frictional losses "per hour" . To determine which engine can either haul a larger weight uphill in the same period of time. Or raise the same weight in a shorter period of time.
If lower rpm was better. Why did Ag manufactures change from a 540rpm pto to a 1000rpm pto to handle higher HP instead of a 250rpm pto?
How it a race to haul live stock like a Nascar event uphill faster? As long as the vehicle keeps up with traffic in the right lane, it doesn't matter. How do you need 400HP to haul typical under 10,000lb load and rarely do any real world pickups haul 26,000lbs. A short time ago a 318 used to be considered just fine to haul 40 ton of freight plus the truck across country over two mountain ranges.
What era of diesel engine "power" are you comparing to gasoline "power"?
Reliability? Reliability or a modern epa diesel? Who are you kidding? It's been a long time since the glory days of the simple reliable 6BT and mechanical pump ISB Cummins diesel trucks. Ever have anything to do with any diesel with common rail high pressure injectors? Ever have anything to do with particulate filters, glow plugs, cooled egr, urea injection, cat converters, variable turbo's, two alternators, two batteries and more expensive filters.
I haven't seen a gasser wax up a fuel filter either. Last time I checked gasoline runs 20% or so cheaper than diesel. It's been a while since the mid 2000's diesel price advantage at the pumps.
I suppose if you have the money to spend on the luxury of a diesel in 2014. The glory days of diesel pickups and low diesel fuel prices from 1989 to at most 2006 is past.
I see the old chev port injected 6.0 with a Crew cab, standard box with single rear wheels:4x4 w/ 6.0L (4.10 axle): 5,897 / 13,000 or.......
4x4 w/ 6.6L (3.73 axle): 5,897 / 13,000. Both 13,000lbs.
Crew cab, long box with dual rear wheels:4x4 w/ 6.0L (4.10 axle): 5,987 / 13,200 or........
4x4 w/ 6.6L (3.73 axle): 10,206 / 22,500
Really just how many pickups out there have the paperwork and driver with a class A to haul a trailer over 10,000lbs ?
As for max weight in the pickup box, the gasser wins.
Crew cab, long box (2WD) with dual rear wheels: 6.6L: 5,908 / 13,025 gross, 6.0L: 2,833 / 6,245 payload.
6.6L: 5,908 / 13,025 gross, 6.6L: 2,488 / 5,484 payload.
As for power, the old outdated port injected gasser still makes more power until any recent diesel.On cheaper fuel.
Horsepower (hp @ rpm): 322 @ 4,400rpm
Torque (lb-ft @ rpm): 380 @ 4,200rpm
Recommended fuel: Regular unleaded or E85
Ratings for the last simple and reliable Cummins.
For the 2001–2002 model years, a standard output and high output ISB Cummins engine was offered. The standard outputwas rated to 235 horsepower (175 kW; 238 PS) and 460 pound-feet (624 N·m) when equipped with either a manual transmission or automatic.
The high output ISB was rated at 245 horsepower (183 kW; 248 PS) and 505 pound-feet (685 N·m), and only a NV5600 six-speed manual transmission.
In 2001-2002 . All that could be heard was just more powerful the diesel was than gasoline. Looks like 235HP and 245HP.
With a common rail prior to 2007. Midway through the 2004 model year, the Cummins 600 was introduced, producing 325 horsepower (242 kW; 330 PS) at 2,900 rpm and 600 pound-feet (813 N·m) at 1,600 rpm.
Stihl KM 130R String Trimmer and Edger (A49461)
Stihl KM 130R...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
Pump Jack with Battery (A49461)
Pump Jack with...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
