Pulled the trigger on a 5100M
/ Pulled the trigger on a 5100M #1
Mistyridgefarm
Pulaski, TN
JD 5300, JD5100M
We'll, finally did it. My 5300 has been working its tail off by itself doing squares and rounds. Yesterday I finally bit the bullet and ordered a 5100M. I got the deluxe cab, 16F/R trans, H260 loader, and a few other options. for those looking at price comparisons, the list price was $89k list, dealer quoted $73k with them adding liquid ballast.
Delivery on or before July 7.. Now the wait begins! I don't know what I'll do in second cutting without bugs, dust, and scorching heat. I'll post some pictures when it comes home.
Has anyone here with the 2014 5100 or 5115Ms had any problems or issues to look out for?
/ Pulled the trigger on a 5100M #2
Sounds like a nice tractor coming your way.:thumbsup:
I looked at a 5115M OS and a 6125E cab with 16/16 reverser with a price in the window of $86k both nice tractors but I will stick with cab only. I was looking to see if they had a 5100M or 5115M with cab but not in stock. Will be watching to see how you like yours after a little work time.
/ Pulled the trigger on a 5100M #3
we bought a 6105D cab 4x4 rigged up for a loader for $56000.the tractor is prolly heavier than your 5100M.our 605d weighs 12000lbs.if we wouldve put the loader on it it wouldve been $67000.
Thanks for all the comments. It is really hard waiting for the new girl.
/ Pulled the trigger on a 5100M #6
Congrats! Should be an awesome tractor for haying.
/ Pulled the trigger on a 5100M #7
The price has really bumped up this last year. I think it is because of all the pollution junk they are putting on them. Someone has to pay for that stuff.
I've been watching the build price for several years. Just a rough estimate but it looks like a 3% per year increase in base price over the last few years. It is hard to tell though as the engine went from 95 to 100 hp. On this one, I pretty much got every option except I stayed with the 16 f/r tranny. I ordered the triple mid and rear SCVs and the premium cab (not available when I first started tracking this series). The price also includes loading the rears and a heavy duty scrap grapple bucket.
I wish the price was lower but I don't feel it was too bad, especially with the 0% for 60 month financing. The list price not including the grapple was almost $90K so they discounted pretty good.
Well, I've been so busy putting the new girl to work, I have been remiss in posting. The tractor did arrive second week of July and it took the dealer two weeks to prep it out. It makes my old tractor look puny. I had some trees cleared in April with a big dozer to run some new fence. I had already cut off the stumps and moved most of the trees and stumps out of the field. There was still two large root balls I couldn't move pulling with the 4x4 truck while pushing with the 5300. I brought the new girl around and hit one of those root balls, and she never even grunted. I pushed them with hardly a bit of wheel spin! She is a beast. Over the last three months, I've cut hay, baled (squares and rounds), stacked hay, graded dirt, cleared trees, and bushhogged with it. The 5100M has is performing great. It is way more comfortable to operate. I love most everything about her. The plus up features I ordered (never saw one on the lot) was the 3deluxe SCVs, deluxe cab (sunroof), and third function mid-hydraulics. I added a KA Attachments scrap grapple and working logs, brush, rocks is purely fun now. The extra features were worth the money to me. While the 16x16 power reverser is nice, I sure wish I had opted for the 32x16 trans. For cutting hay, I find a need for speeds making me shift between B4 and C1 gears. Oh well, it was my fault. I knew I should have gotten EVERY option and then I wouldn't miss anything. So, loads of great stuff on this tractor but I should also post a few quirks found so far. First, the brakes seem weak. I'm a big guy and when I have to stand on the petal to stop, it means it takes too much! The dealer checked them out and claim they are normal. It is a real PITA re-acclimating when switching between the tractors.
The H260 loader is solid and powerful, but a couple of points on it: 1) with the bucket level, the lip is 2" or so above grade. The lift cylinders are fully retracted. I'd prefer the boom to go all the way to the ground. 2) at least on the cab version, the loader frames are more forward on the tractor than my old 520 loader, giving a lot more leverage on the rear wheels. I have my rears fully loaded and max width but I still need significant rear weight to lift a full bucket of dirt without having them come off the ground. You can guess how I know! Fortunately I dropped the bucket fast enough to get them back down before the tipping point. I recommend a good 2000 lbs of implement ballast if you want to safely maximize the loader capability.
All in all, an awesome machine that is comfortable and capable. She will be part of our farm for a long time.
Forgot one tip - If you want mount any items to the built in threaded holes in the cab, go to RAM type mount supplier. The threads are 10mm and RAM makes a ball socket to fit. Then go from there. I saved over hundred bucks on just mounting my bale monitor.
/ Pulled the trigger on a 5100M #12
Very nice tractor! Glad it is working out how you want.
/ Pulled the trigger on a 5100M #13
That seems odd. Deere list the digging depth for that loader on a 5M tractor at 5 inches. You're saying you can't get a level bucket down to grade? If so, I think you have a setup issue.
Well, it will dig, but you have to angle the bucket downward. I looked at the specs and you are correct that it says 5" digging depth. I see no adjustments or settings that could be changed. My 520 loader has to positions to put the lift rod ends in to switch between digging depth and maximum height. The H260 does not have this as an option.
/ Pulled the trigger on a 5100M #16
It's hard to see in the pictures but this is my 5105M with an H260. With the bucket level it just lifts the front wheels clear of the floor. The front tires turn freely by hand.
I didn't get home before dark so I could not get pictures. BigBlock, I noticed you have the skidsteer attach. Mine is the Global. I wonder if the attachment points on the bucket are too low, raising the bucket higher in relation to the dump pins? Would you mind measuring from the floor to the grease zerk on the bucket pin on loader side. I'll measure mine tonight for comparison. The one I mean is the lowest on the loader arms.
Also, I found my first drip last night. Looks like there is a very small hydraulic leak near the rear axle, just right of center. My son is going to look harder this afternoon in the daylight.
/ Pulled the trigger on a 5100M #18
Those aren't skidsteer mounts, they are regular John Deere mounts. The global should put things in the same place ( I thought). Do the loader mounts themselves have any adjustment? Or maybe the wrong mounts are on the tractor?
It just can't be right not to be able to scrape (and dig) with a level bucket.
/ Pulled the trigger on a 5100M #19
Arlen4720 is correct. That is the standard JD mount. I will try to measure tomorrow if I don't get called to work early.
/ Pulled the trigger on a 5100M #20
Also, maybe both of you could list your tire sizes...that has to play a role somehow
2017 Crane Carrier Co. G-S Products 23yd Dual Side-Load Refuse Garbage Truck (A66736)
2017 Crane Carrier...
2025 Hydraulic Tire Lifter Skid Steer Attachment (A66734)
2025 Hydraulic...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2014 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2014 Chevrolet...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2017 Dodge Ram...
