MY2012 5085M ordered today!
/ MY2012 5085M ordered today! #361
I agree the 90s pointing towards the implement and longer hoses would be the best.
My first suggestion was to try and make better what he has.
I agree, which is why I posted.
pclausen, put the 90 at the tractor end at a 90 to the cylinder pointing to the right as it is, but 90* to the cylinder . Put the 90 at the rod end pointed straight back towards the tractor and put the hose back over to the left side. That should work out for you, if not, a couple of hoses would be pretty cheap. ;)
Right, I'll play with what I got first. This is another board member's tractor and I used the same length hoses. I'll maybe try to re-arrange my hoses like he has them.
In other news, the tech came back out today. He had done some research and found that the code my tractor was throwing was a known issue and the fix was to upgrade the engine control module. The tech went ahead and upgraded all the modules to the latest version while he was at it. Problem appears to be solved. I have not seen the malfunction light since! :)
/ MY2012 5085M ordered today! #363
Your re-route job is excellent! I was pretty convinced that you'd end up with a big wad of excess hose at the top - near the single point connector. Surprise... surprise! :thumbsup:
I'm gonna have to get mine in the garage and do a reconfigure as well.
Headed south on Monday to the lower 48, though.
Be back in 3 weeks or so.
AKfish
My 5085M now has 20 hours on it and I figured I'd write a quick review of my my experience with this tractor so far.
2.3 hours - This is what was on it when I first saw it at the dealer the day it was delivered. Drove it around the lot for maybe 10 minutes. Very powerful, and very tight.
2.9 hours - After dealer Pre Delivery Inspection, which consisted mainly of the dealer running the tractor on the PTO dyno (made 85 PTO HP!), after filling up the 52 gallon fuel tank.
4.0 hours - I spent some time just playing around with my new toy and finish moving a couple of acres, switching between 540 and 540E PTO speed. Cabin was very quiet at both PTO speeds. A/C worked extremely well (about 90 degrees and humid conditions).
5.0 hours - I picked the tractor back up from the dealer after having the H260 FEL installed. I really like the action of the control joystick. I can feather it much better than the joystick on the 460 loader I had on my JD4700 CUT. Very precise control. Hydraulic power is incredible. I was able to pick up a ~3500 lbs car with my forks at 1200 rpm with no issues.
7.0 hours - I used the FEL to place 24' roofing panels on my pole barn. Really appreciated the self leveling of the FEL in placing the panels. I did have an issue with the check engine light coming on on about every 4th engine start. Dealer flashed all the modules to the latest code version, and the issue went away.
10 hours - I drove the tractor about 4 miles down the road (black top) in the following configuration:
I absolutely love the hydraulic top link! It made raising the cutter up for transport so much easier, and also made it real easy to use the cutter as semi-mount without having to leave the seat.
Top speed going down the road in D4 was 22.2 mph. Even during WOT and downshifting to maintain speed up steep hills, there was absolutely no smoke coming out of the stack. I guess there tier 4 engines are running very clean.
I did stall the engine once running in 540E hitting a mound of dirt. I guess I need to adjust the slip clutch on the cutter!
I had to clear several large trees and relocate an existing burn pile to another location. The loader suspension system is fantastic. Heavy loads appears to just float along on the loader moving across bumpy terrain.
Cutting some very steep terrain, I did manage to get the tractor up on 3 wheel with one rear up in the air a little. I normally don't plan to have the grapple on when cutting except the first time each season to pick up fallen trees/limbs, so I don't expect this behavior with the FEL disconnected. I might consider adding another pair of rear weights, and maybe even 40% rim guard.
Going down very steep slopes, windshield fluid would pour out the front wiper nozzle. Might need to add a check valve to prevent this. :D
In all, I managed to clear about 10 acres of trees and cut the grass/brush in about 8 hours. Temps were in the 90s and at no point did the engine temp get above mid mark.
18 hours - I detached the FEL. It was a bit tricky to apply just the right amount of down pressure to allow releasing the lock pins holding the loader from the the tractor brackets. I'm sure with practice I'll get the hang of it. Love the drop down feet. The single point disconnect is great, no oil mess or oily hands. Put the finish mover deck on and cut about 5 acres, again varying between 540 and 540E. The sound quality of the speakers leave a lot to be desired. I'll need to look into upgrading them. It might be the radio electronics, but I suspect its primarily the speakers themselves.
20 hours - I was down to half a tank and filled back up. It took 26.3 gallons to fill completely up to the filler neck. So I averaged 1.48 gallons per hour. Keep in mind that this included the dealer dyno run, and me spending 40% running 540 PTO, 40% running 540E PTO, 15% running wot or close to it on the road and in the fields, and maybe 5% idling at 1200+ rpm doing roof panels and what not. I'm sure that once I get this thing broke in and use 540E for everything and don't flock is so bad, my fuel economy will get a lot better.
Heading to the dealer today to sign the paperwork and make it mine officially. So my 2 year warranty and 60 month 0% w/ insurance officially starts today. Good thing I didn't break something on it over the weekend. :D
/ MY2012 5085M ordered today! #366
I knew you came through of driving the tractor there! What do you mean by WOT? I have 85 hours on my 6430 now, Yesterday a guy down the road that had a Kubota M108X that got stuck and he said he pay me $100 to pull it out and I agreed on it, drove 5 minutes down the road to pull him out. I told him, "if you bought a green tractor with yellow rims, this wouldn't be happening". :laughing: Not really a fan of the new version of the site, I cant edit my "about me" thing, my list of tractors goes right into the post :(
Lol, I was trying to figure out how to update my profile to show my curernt tractor model as the one shown is incorrect. The MY HOME icon doesn't appear to be working.
WOT = Wide Open Throttle :D
I now have 42 hours on the M. Only issue I have had is that the gear cog light has come on about 10 times. Putting the tractor in neutral for about 10 seconds always fixes it. I'll have the dealer come out and get the codes at some point. Other than that, no issues at all and I have truly been abusing, I mean properly breaking it in. :D :D
It is starting to look well used. Look, someone wrote on the hood. :)
Someone asked if I cleaned my boots before entering the cab, not so much!
Oil, dust and grime has started to accumulate at the back.
Soon I'll have a nice protective coating on the whole tractor. :)
/ MY2012 5085M ordered today! #369
It's starting to look like it's earning it's keep around there! Glad to see your not afraid to get it dirty :D
I have a question about your 540E setting. What would you figure for hp that your getting at the PTO when in the "E" setting?
I haven't noticed any issues at all using 540E with the 90" finish mover, nor with the heavy duty 9' dual spindle bush hog. The RPMs drop to maybe 500 or so pulling through thick growth at 5mph compared to maybe 520 in regular 540 mode.
The only noticeable difference is when using the stump grinder. It does not like 540E at all unless you go real slow.
/ MY2012 5085M ordered today! #371
Good question! If IRRC pclausen had a dyno run before delivery. He might have a print out of the HP at different RPMs and could tell you what it made at ePTO engine RPM.
/ MY2012 5085M ordered today! #372
That would be interesting. It would be neat to know what sort of 'equivalent' hp it would be at the E setting. I'm curious because I know you mentioned that the stumpgrinder works considerably better without the E and using the full 85hp of the tractor pto. I'm keeping a running list of things to consider for my next tractor purchase years down the road, and this could be helpful information :D
That's a good idea. After I change my break-in oil at 100 hours, I see about having it run on the dyno again on both 540 and 540E. I'll also check to see if the dyno is capable of producing a hp/torque curve as is typical of car dynos.
/ MY2012 5085M ordered today! #374
Nice update pclausen, glad to see you getting some use out of it! Any pictures/updates on the barn project?:)
Barn is pretty much all done except for the floor. I'm going to wait a bit for that until things fully settle.
I can get to the 10' cutter, stump grinder and 90" finish mover without having to move stuff around, and the 24' GN trailer, all up against the rear wall.
I have gotten pretty good at taking the loader on and off.
Disking virgin uneven terrain is much better without the loader on. It gets quite bouncy at 6mph! I'm loving the EH hitch. The only thing missing would be if the top link cylinder would go out of float automatically when I raise and go back to float when the disk is on the ground. I suspect that the 6 series and up with the Electronic rear remote controls can be programmed for this.
Full view of the additional 2 bays on the existing shop.
View from the house.
I'm just about the hit 60 hours on the M. It feels like it keeps getting stronger!
/ MY2012 5085M ordered today! #376
Disking without the loader on reminds me of driving a sports car, way more maneuverable. :thumbsup:
/ MY2012 5085M ordered today! #377
:shocked:Thats the Best shop area I have seen! Im Jealous
/ MY2012 5085M ordered today! #379
Very nice job on the addition. Roof lines show you got it nice and square (not easy to do).
What is the little jog in the front roof line just after the new roof starts? Is it longer to cover sliding door tracks ?
Bet you love the multicoupler when removing/attaching the loader!
Thanks! This pics shows it real well.
What is the little jog in the front roof line just after the new roof starts? Is it longer to cover sliding door tracks?
The addition has a 1' overhang where the original had none. This pics probably shows it better. Down the road I might consider sliding doors. The big storm the other week left quite a mess inside.
Yes, so much easier than dealing with the individual hoses and no mess at all!
2017 Ford Transit 150 Cargo Van (A66736)
2017 Ford Transit...
THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
THE MACHINE CO...
CAT 621B Final Drive (A68134)
CAT 621B Final...
1143 (A63745)
1143 (A63745)
3148 (A63117)
3148 (A63117)
25057SFL (A64557)
25057SFL (A64557)
