Rear Finish Mower Pull type
   / Pull type #11
Try your local TSC or similar store. Even if they don't carry it in stock, They should be able to order it in for you. My local TSC does not carry the land plane, leveller, etc. But in the catalog of equip. manufacturers the carry it was listed and were able to put it on order for me. they should be able to order in a pull rotary mower for you. or a finish mower if that is what you need.
Good luck
Tom
   / Pull type
Tom
Thank you for that. I will call them tomorrow. I have checked them out but only their catalog.
   / Pull type #13
Don't know if I have ever seen a PTO driven pull behind mower, but you can solve the tire interference by using a drawbar to pull from.[ame=http://www.amazon.com/Special-Products-04010100-3-Point-Drawbar/dp/B004RQ1PRK]Amazon.com: Special Speeco Products 04010100 One Piece 3-Point Hitch Cross Drawbar: Automotive[/ame]
   / Pull type #14
Have tried using a pull-behind brush hog run off the PTO and it is a PITA. Turn too sharp and the U joints let you know.
   / Pull type #15
On my tractor the mower is hydraulic and mounted on the front. 96" of pure brilliance. Why not go in a different direction and mount a hydraulic mower upfront?
   / Pull type #16
I'd also be worried about the mower hitting a rear tire when making a turn...that could result in a bad day!
But, there are pull type rotary cutters..and a number of people operate them. Maybe someone will chime in and tell us what prevents PTO damage and the tire interference.
two CV joints ( one at tractor one at tongue pivot) on the MoCo lets you turn sharper than single U-joint. I think single U is about 15 degrees, CV close to 30*
   / Pull type
I am not sure the hydraulics on my tractor could handle it.
   / Pull type #18
Another way to avoid tires hitting the mower on turns is a swinging hitch but I don't know if they put them on newer machines.
   / Pull type #19
The big advantage a 3 pt mower has over my riding mower is that it still cuts when I am going backwards. And because it was so low to the ground, I could back it in to any corner or under any tree, without having to worry about it getting hurt. I think that motor sitting right on top of a pull behind would have got in the way.
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2010 Kubota ZD326 60in Zero Turn Mower (A55851)
2010 Kubota ZD326...
Dry Gel Hydration Unit (A55745)
Dry Gel Hydration...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A57024)
LIKE NEW 2023...
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
