Spreader Pull behind spreader recommendations?
/ Pull behind spreader recommendations? #11
I use the Lely ground driven pull behind model in my turf business. It fits my needs well, but it cost a lot more than some other models.
It is a true 'commercial' spreader. But....they are a little over $5000. Here is a link. Ground Drive Broadcast Spreader | Lely Ground Driven WFR
/ Pull behind spreader recommendations? #12
KK makes a nice pull behind spreader <I believe it holds 500 lbs.for around 700 buckc
Thank you, $5k is a bit steep but probably a great investment for a commercial lawn business, however I always like to buy pro products.
/ Pull behind spreader recommendations? #14
I spread fertilizer on about 12 acres every year. We have a farm fertilizer supplier here that will fill a field spreader with the fertilizer that you order and rent the spreader to you. I get enough to spread on my pastures and yard. They can even mix pell lime with it.
That's a great service, easy-peasy for you. This is primarily ranch country with some hay being grown so we don't have any bulk suppliers like you are using as far as I'm aware of.
I think I'll postpone buying a pull spreader for a while, I just committed to buying a 300 gallon gravity feed tank for dyed diesel - $1200 plus a minimum of 150 gallons of fuel. I filled my 50 gallon portable tank yesterday and off-road diesel was $1.799 a gallon - it's the lowest I've seen in years and years. So I thought this would be a good time to buy a bulk quantity. The tank price includes hose, filter, nozzle and delivery/setup. Delivered fuel price is 20 cents more than at the pump which is fine with me.
My bulk supplier sold all of the tanks he had and he put in another order and already three of the incoming tanks are sold, one of them is mine :)
Thank you all again for the recommendations! Stay safe out there.
/ Pull behind spreader recommendations? #16
Look at the Befco Baby hop.Nice pull behind spreader.
/ Pull behind spreader recommendations? #17
When you decide you are ready, I bought one similar to this off of craiglist, used like new. I like the versatility of being able to use atv, tractor or truck and still has a relatively large hopper.
eBay
I've looked at the Baby Hop, that one was on my short list. Checking Craig's List is a great idea but I'm not going shopping in person until this Kung Flu thing is over.
Box of Transport Ratchet Straps (A59230)
Box of Transport...
1997 International 4800 4WD S/A Dump Truck (A59230)
1997 International...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
John Deere 5525 (A60462)
John Deere 5525...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
