Pull behind compact log skidders????
/ Pull behind compact log skidders???? #1
Maka
Granbury, TX
1620 Ford with loader
Hi All,
This may seem a bit different but I am looking for a log tong/grapple/log skidder that pulls behind on a hitch (not 3 point). I would want it hydraulic with an opening of up to 18". Does something like this exist to anyones knowledge?
Thanks,
Maka
/ Pull behind compact log skidders???? #3
The hydraulic is probably not necessary. I have seen demonstrated a logging arch by Future Forestry Products (check on google) it will handle a log up to 24 ft long behind a 300 cc honda 4 wheeler. It has a boat type winch to haul the log up so its up off the ground. You can just run the 4 wheeler up next to the log then get off and throw the arch over the log or go a little past and back it up to the log. It sure looked easy
Martin
/ Pull behind compact log skidders???? #4
Don't forget you still need traction to pull that log. Might be OK on flat land or a light log but here in Ontario they have proved very frustrating unless the logs are short and light, in which case we just hook a chain to the log and hook it to a nylon rope behind the ATV.
TANK MANIFOLD (A67714)
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2014 Ram Pro Master 2500 Cargo Van (A66736)
2014 Ram Pro...
CAT 345CL NEW Track Chains (A68134)
CAT 345CL NEW...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
