Pull behind compact log skidders????
/ Pull behind compact log skidders???? #1
Maka
Granbury, TX
1620 Ford with loader
Hi All,
This may seem a bit different but I am looking for a log tong/grapple/log skidder that pulls behind on a hitch (not 3 point). I would want it hydraulic with an opening of up to 18". Does something like this exist to anyones knowledge?
Thanks,
Maka
/ Pull behind compact log skidders???? #3
The hydraulic is probably not necessary. I have seen demonstrated a logging arch by Future Forestry Products (check on google) it will handle a log up to 24 ft long behind a 300 cc honda 4 wheeler. It has a boat type winch to haul the log up so its up off the ground. You can just run the 4 wheeler up next to the log then get off and throw the arch over the log or go a little past and back it up to the log. It sure looked easy
Martin
/ Pull behind compact log skidders???? #4
Don't forget you still need traction to pull that log. Might be OK on flat land or a light log but here in Ontario they have proved very frustrating unless the logs are short and light, in which case we just hook a chain to the log and hook it to a nylon rope behind the ATV.
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
2018 JAYCO JAY FLIGHT CAMPER (A67714)
2018 JAYCO JAY...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65056)
2021 CATERPILLAR...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
2012 Toro GroundsMaster 3505-D 72in. 3-Deck Commercial Rotary Mower (A66734)
2012 Toro...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A67714)
2017 FORD F-150...
