Pull behind compact log skidders????
   / Pull behind compact log skidders???? #1
Maka
Veteran Member
Pocatello
None at the moment
Hi All,
This may seem a bit different but I am looking for a log tong/grapple/log skidder that pulls behind on a hitch (not 3 point). I would want it hydraulic with an opening of up to 18". Does something like this exist to anyones knowledge?
Thanks,
Maka
   / Pull behind compact log skidders???? #2
Maka,
Why Hydraulic? There are a number of log arches which would fit the bill except for the hydraulics. Some use a manual winch to raise the log, others raise it as you pull the arch forward. Several are designed for a hitch behind an ATV.
For Instance :
Portable sawmills, forestry equipment and ATV attachments
Hope this helps.
   / Pull behind compact log skidders???? #3
The hydraulic is probably not necessary. I have seen demonstrated a logging arch by Future Forestry Products (check on google) it will handle a log up to 24 ft long behind a 300 cc honda 4 wheeler. It has a boat type winch to haul the log up so its up off the ground. You can just run the 4 wheeler up next to the log then get off and throw the arch over the log or go a little past and back it up to the log. It sure looked easy
Martin
   / Pull behind compact log skidders???? #4
Don't forget you still need traction to pull that log. Might be OK on flat land or a light log but here in Ontario they have proved very frustrating unless the logs are short and light, in which case we just hook a chain to the log and hook it to a nylon rope behind the ATV.
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
