Pull-Back collar on PTO shaft
/ Pull-Back collar on PTO shaft #1
Jack42
Deere Model 3039R
Hi,
New member here with arthritis in hands. I just spent several hours kissing, cursing and aching, trying to get a very well lubricated driveshaft onto the Deere's spline. Damn thing kept insisting I buy it dinner first!
Short version, My hands (at 74) are no longer strong enough to Hold back the collar to release the ball bearings while pushing the shaft forward. I can still do the rods ok, and the twister ok, but the pull back defeats me.
Finally got it on with second person tapping on the collar as I pulled back.
Question: does anyone make a strong enough clip to hold the collar back until mounted?
or
is it easy to replace the pull back collar with a rod collar? or a twist collar?
Thanks
/ Pull-Back collar on PTO shaft #2
G'day Mate and welcome to TBN from Downunder.
Did you raise the implement to a height where the driveshaft was parallel with the PTO?
/ Pull-Back collar on PTO shaft #3
This is what I did for a mid mount mower shaft. Can’t take credit someone else had the idea. Works well.
/ Pull-Back collar on PTO shaft #4
I hate those pull back collars! My solution was to replace the yoke with one of the push pin type yokes, I would have used the twist type if it had been available locally. If I remember correctly it cost about $40 to change it. Money well spent to no longer have to put up with the frustration.
/ Pull-Back collar on PTO shaft #5
All of mine are old and have the push-pin release. Even those can be cantankerous at times if not kept lubed. I have to make it a point to include them in my routine maintenance rounds as all my equipment is stored outdoors.
The hair-pin idea is a good one even if revisited. Was the "hole" already there? Ball removed? Drilled? :unsure:
/ Pull-Back collar on PTO shaft #6
Switching to the push pin type can help. Also, use a bungie cord around the top link to hold the pto shaft up. Then you can concentrate on getting the shaft connected. I can't take credit for that idea, someone here posted it. Most pto shafts will slide onto the tractor's pto stub for a short ways before you need to release the locking balls to fit it the rest of the way. You can slide it on partway then unlock the balls to get it on the rest of the way.
/ Pull-Back collar on PTO shaft #7
Maybe look into some of the new pto easy attach units. They are a little pricey but seem to make it very easy to connect. There are pop up adds on you tube for them.
/ Pull-Back collar on PTO shaft #8
You can swap out just the end of it (or pay someone to do it for you).
Not sure what kind of PTO shaft John Deere uses... if it's like anything else JD, they have a proprietary connection.
Agrisupply has other ends depending on the class of pto shaft: (not saying this one works)
/ Pull-Back collar on PTO shaft #10
I had a little go round with my blower shaft. Wound up putting on a hose clamp once it was pulled back. Worked pretty good.
Maybe consider something like this...
Dale
Hi, don't really want to do 3-5 hundred dollars just to beat a JD piece of stubborn into shape. But thanks for information. I like the hose clamp idea though and the $40 replacement of the pull back collar. Thanks to all of you.
G'day
Thanks, no - it wasn't level, the rototiller was down about five degrees from the PTO shaft so there was definitely an uphill tilt. Thanks again.
/ Pull-Back collar on PTO shaft #14
Maybe they will come down in price after a while, when they get more known and popular? (Economy of scale.)
/ Pull-Back collar on PTO shaft #15
A combination of mistakes on my part caused me to replace the pull back connector on my post hole auger with a push pin type I already had. It's easier to hook up now.
/ Pull-Back collar on PTO shaft #16
Dale
Have to laugh at their “old wise farmer” model. His clothes have never seen a day of work in their life. Looks like the tags are probably still on them. .
...but maybe with that PTO system they stay that clean.
/ Pull-Back collar on PTO shaft #18
Interesting but a little more detail will help.
What's going on here? What kind of clip? How does it keep the collar ope n?
/ Pull-Back collar on PTO shaft #19
I don't have a problem with them.
Ignore the collar. Push and turn the joint until it slides onto the splines. It will stop when the collar's latch hits the end of the PTO shaft. THEN pull back the collar and push the joint on all the rest of the way.
The difficulty comes from pulling back the collar from the beginning, while trying to align the splines, when it is not needed.
Bruce
/ Pull-Back collar on PTO shaft #20
Bruce
My gosh. Does that really work? I’m so stupid!
MoKelly
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
JOHN DEERE 8335R TRACTOR (A64276)
JOHN DEERE 8335R...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61572)
2024 Kubota...
20ft 2-Door Shipping Container (A61572)
20ft 2-Door...
