PTO
   / PTO #1
GIMiller
2010 Massey Ferguson 1648
PTO just stopped working..
   / PTO #2
Little more information needed... also I don't know your model so; is it electronic PTO (push button for on?)
Did you hit anything before it stopped working? Was it running fine and then stopped?
If it's electronic and happen over night, a mouse could have chewed a wire... (wild a$$ guess...) Check fuses?
   / PTO
I have a 2010 1648 .. I gave mowed pastures about a month ago worked fine.. Mowing yesterday driving along and PTO stopped turning during mowing... No noises or anything..
I'm looking for maybe a way to troubleshoot the problem as O don't know where to start..
   / PTO
Electric pto
   / PTO #8
Electric pto
Completely different machine, but mine did the same thing. If you try to activate the PTO, do you smell anything odd?
Mine has a small solenoid/coil on the side of the transmission. Rotating the PTO switch powers the solenoid which pulls something inside the transmission to engage the PTO. When mine quit, I could smell that electrical burning smell if I tried to turn it on.
Turns out that solenoid failed internally. Never blew a fuse though. So, start with fuses and wiring that may have gotten pulled loose or broken. Try to locate a similar solenoid on your machine and see if you have power to it.
   / PTO #9
Does your mower have a shear pin in the U-joint by the tractor? Last year my snowblower sheared that pin so it looks like your PTO is not turning when in reality it is fine you just to replace the shear pin.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2020 VOLVO VN SERIES SLEEPER (A55745)
2020 VOLVO VN...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
2015 DRAGON  130BBL VACUUM TRAILER (A55745)
2015 DRAGON...
