Pto
Lea
Fort Frances Ontario
john Deere model M kabota 2320 TLB
Can anyone tell me the size and speed of front facing pto on a Kubota B2320 and the # of splines
Thank you
/ Pto
I can't believe it either charlyktractor I didn't think it was that tough a question
Here are the 2320 specs Kubota Tractor Corporation - Tractors | B Series | B2320/B2620/B2920
The mid pto speed is 2500. It does not mention spline size. I will see if my snowblower has a size listed.
This post http://www.tractorbynet.com/forums/...440-front-mount-snowthrower-b2781a-b2782.html mentions "mid PTO (10 spline 31/32")"
and the only specs I was able to find from Kubota are for the rear:
POWER TAKE OFF
Live Continuous Running
Rear PTO 2 Speed
SAE Std 1 3/8 Six Spline
540 rpm @ 2773 Eng. rpm
960 rpm @ 2722 Eng. rpm
Mid PTO 1 Speed
2500 rpm @ 2750 Eng. rpm
from this document:
http://tinyurl.com/n4jzogc
I have a BX25 and the dealer told me if I wanted a MMM I had to get a K brand as nothing else will work. He also stated the Mid PTO shaft is unique to Kubota and difficult to match for driving snow blowers and MMM. Take that with a grain of salt. My BX manual says it is 17 HP at 2500 RPM also and the spline is: USA #5 (Kubota) 10 tooth involute. That info is on the Specification page of the manual. I would bet yours is the same, check your manual or check with Messicks a TBN advertiser Kubota dealer for confirmation. Time to walk the net if you are looking for some kind of non-standard match-up parts.
Ron
Tractor Seabee has it correct, according to my B2320 Manual. 2500 RPM is at 2750 engine RPM. Spline is USA #5 (Kubota) 10 tooth involute.
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
