PTO won't engage
/ PTO won't engage #1
jrashkosr
MT125
I checked the PTO switch and seat safety switch, both work. What is another place to check?
/ PTO won't engage #2
fuse? power to the switch? grounds?
/ PTO won't engage #3
Verify that your PTO selector is in either rear/both/front and not between settings,
Also you may need to lift and lower your 3 point to be able to run the pto.
/ PTO won't engage
Ok checked all that, late bloomer to the tractor world, LoL. Where is the PTO located exactly, thanks
/ PTO won't engage
PTO solenoid located?
/ PTO won't engage
Thanks for your reply, I have a mt125
/ PTO won't engage #9
I believe if your not sitting in the seat the transmission has to be in neutral and the parking brake needs to be on in order for the PTO to work.
At least that’s the way it works on my XR4155 .
/ PTO won't engage #10
I think I remember those days :unsure:
I bypassed a few safety switches, including the seat switch. I don't remember a parking brake switch, but mine is the gear model, so might be different? I can reach into the cab, without being in the cab, and turn on the PTO. Sounds kinda scary, but I make sure all is safe before doing this. Makes adjusting slip clutches much easier when I don't need to get on and off several times. Thats about the only time I do that.
Still havent relocated my switch to the side console yet either. So many projects, so little time.
/ PTO won't engage #11
Also - if you have an implement attached and it's not working - make sure the shear pin didn't break.
I spent about an hour once trying to figure out why my PTO wasn't engaging only to find out that the PTO was fine and the shear pin had broken.
3pt Heavy Duty Carry-All, 3'x6' Platform (A62679)
3pt Heavy Duty...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
2015 Ford F-150 Pickup Truck (A62613)
2015 Ford F-150...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2024 John Deere RS72 Skid Steer Cutter (A65640)
2024 John Deere...
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
