pto will not engage ls xr4145hc 26 hours
   / pto will not engage ls xr4145hc 26 hours #21
Yes, I meant nut. The finger tight plus a 1/16th turn ... where did you reference this? Seems like loc-tight might be in order. Just searched my repair manual and don't find it. I assume the dealers don't use the same manuals.
   / pto will not engage ls xr4145hc 26 hours #22
'University of Life' graduate.
1/6th Turn - Not 1/16th. Loctite if you really want.
going to pick her up tomorrow
dealer said bad coil
still dont explain why it popped fuses when disconnected
said they ran it an hour no problem
   / pto will not engage ls xr4145hc 26 hours #25
Remember this post?
thanks for the help from the land down under
you are correct
i could take it so i walked out to shop disconnected the harness at solenoid
15 amp fuse in fired up ole blue
turned pto switch on pop
i heard fuse go
With no solenoid coil connected the fuse did blow... :irked:
So I'm not sure they have fixed the whole problem. But if you're able to go mowing, get out there!
Thanks for the follow-up anyway.
I will talk to service manager tomorrow. I bet the May of found something else too. No telling. I did mark the coil to see if they actually changed it
Makes me want to buy a spare
   / pto will not engage ls xr4145hc 26 hours #27
Wise move with the mark on a part. When I was a kid, I was in horror at a man I worked for that said he replaced parts on cars when he did no such thing but charged them full price. I quit.
Buying a spare is a way to guarantee you will never have that problem again, will die with that unused new coil and you will never even hear of anyone having a bad coil until a week after you finally throw it out from not using it for 30 years. It's a subset of Murphy's Law. You can look it up.
picke her up ran the hog for an hour it is a ok
i saw my old coil they showed it to me so no question a new one was put on
they still couldnt explain why it popped fuses when not connected
oh well we shall see
i got a 2 hour cut tomorrow
Schulte SBW800 Rock Windrower (A56435)
Schulte SBW800...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
1997 international 4900 DT466E (A56435)
1997 international...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
