3-Point Hitch Pto trouble possibly
   / Pto trouble possibly #1
Jeffreylee
Grafton
Tc55d
I was tilling with my TC55DA, when the tiller stopped, I raised the tiller up and it started spinning again, I put it back down and went a little and it quit spinning again. Is there some thing wrong with my pto clutch?
   / Pto trouble possibly #2
Is the PTO engaged completely? My massey will spin a little if I almost put it in gear but will have no power. Ed
   / Pto trouble possibly #3
Dos the PTO shaft stop spinning or just the tiller?
   / Pto trouble possibly #4
When it stops spinning, is your tractor pto still spinning? If yes, does the tiller have a shear pin or slip clutch? Check them.
Post back
   / Pto trouble possibly #5
I posted this response to your other post with this same question:
"Was the PTO shaft from the tractor spinning, but the tiller was not? It can look like the tractor PTO is not spinning because the shield is not. Do you have a slip clutch on the tiller? More than likely, the shaft is spinning inside the shield, and the slip clutch on the tiller is slipping. Readjust that per instructions."
I think your slip clutch on your tiller is just too loose. Mine does the same if it's set up a little too light.
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
2001 John Deere 6210 (A53317)
2001 John Deere...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
2023 CAN-AM DEFENDER XT HD9 CREW RTV (A57192)
2023 CAN-AM...
