PTO sprayers (2 questions)
   / PTO sprayers (2 questions) #11
I have Fimco 60 gal 3 point with a Hypro pto pump and am very happy with it so far. I run the tractor at about 1400 rpm and adjust the valve to about 20-25 psi. It has an internal bypass so the solution stays mixed and a 10' boom and 25' hand sprayer. My only complaint so far is the paint on the frame and boom uses no primer and it fell off pretty quick.
   / PTO sprayers (2 questions) #12
I bought a 3 point 110 gal boomless one recently that was made by Schaben Industries. I haven't used it much yet but am impressed so far. They have a plant in Newton, KS which is close to Wichita. I ordered mine through a JD dealer but I think you can also buy direct from Schaben.
   / PTO sprayers (2 questions) #13
   / PTO sprayers (2 questions) #14
I have recently decided to purchase a PTO operated sprayer. I have enrolled some of my land in a TPWD native grass restoration program. It calls for spraying improved pasture to kill out the bermuda and bahia grass so that native grass can be planted this fall. I am putting in 25 acres this year and may do so each year for the next several years. I also have the occasional need to spray fencerows etc. I will need the sprayer to have a spray wand as well as fold out booms. I have never used a sprayer before. I will be using a Ford 7710 or a NH TB110. Here are my questions:
1) trailer or 3 pt. (what tank capacity)??
2) what are some good brands (USA only please)??
I purchased a 55 Gal hand wand unit from these folks and have been happy.
Ag Spray Equipment - Farm, Lawn, Garden, Spot Sprayers, Parts, Pumps, and Tanks
I custom made a dual 55 gal pto pump operated unit
http://www.tractorbynet.com/forums/attachments/143121-re-build-spray-rig.html
Welcome to The Accuspray Emporium were Smiles are Free was a good source for parts of all types needed to put it together - very helpful folks.
   / PTO sprayers (2 questions) #15
Thanks for all the good info guys! This is one of my next projects so I am listening carefully.
   / PTO sprayers (2 questions) #16
Sounds like the pasture spraying is a one-time preparation spray for the planting of each field, and no maintenance sprays. If that's the case you might consider hiring that out.
Then purchase like a 50-100 gallon 3 pt sprayer with a wand for the fence rows, or even hire that out too if it's so infrequent.
Something to consider.
2011 Jacobsen T-700 Reel Mower (A56859)
2011 Jacobsen...
Hercules Rustic Gun Cabinet Holds 40 Guns (A57454)
Hercules Rustic...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Bunker Rake (A59228)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
