Pto speed linear?
/ Pto speed linear? #21
Does ground speed and pto speed remain linear across the full range of engine rpm's? I've never had my tractor fully up to rated pto speed (engine rpm) while using my rotary cutter. It seems to me a waste of fuel and wear and tear on the equipment to run the engine at rated rpm. You must assume standard transmission and not a Hydrostat regarding this question. Thanks
You are not saving any fuel or wear and tear. It's a farm tractor that is used a few dozen or a few hundred hours per year. It's not a maxed out prime mover for marine propulsion , power generation or irrigation pump duty. Where 24/7 duty at full power is the norm.
The engineers who know far more about the machine than you designed it with a rated rpm to use for good reason. The rotary cutter relies on blade velocity and centrifugal force to operate. Lower rpm reduces both.
/ Pto speed linear? #22
Some wise acre is surely going to come along here and say that the output speed of a PTO shaft varies during each revolution depending on the angle that the pto shaft is run at.
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
2014 LEVIATHAN  T-BELT TRAILER (A67714)
2014 LEVIATHAN...
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2009 WESTERN STAR 4900 SF WINCH TRUCK (A67714)
2009 WESTERN STAR...
2019 MACK PINNACLE (A67714)
2019 MACK PINNACLE...
