pto slip clutch
   / pto slip clutch #11
texbaylea said:
I had to machine about 1/4" off of the female hub to allow the shaft and hub bolt holes line up plus drill out the hole in the mower shaft to accept a larger bolt.
Unfortunately that horse is already out of the barn, but the proper way to make that fit would have been to shorten the shaft instead of grind off the end of the clutch receiver. I suspect more binding problems in your future. The difference in bolt holes could have been compensated for with sleeves. You accomplished the same end, but it would have saved overboring.
//greg//
   / pto slip clutch #12
wow, i "thought" i had located a good price on a slip clutch, sure glad i haven't ordered it yet.
thanks
heehaw
   / pto slip clutch #13
greg
The problem was that the shaft out of the gear box was too short. I could have drilled a new hole through the shaft but that would have weakened it.
Vernon
   / pto slip clutch
Thanks for all the input and the links. It really helped. This is my first time in over 28 years of tractoring that I thought I had a need for this item. great to know that I was wrong with where it mounted. If it was not for the people here, I would have ordered it thinking it went in-line of the tractor end.Learn something new everyday...
   / pto slip clutch #15
texbaylea said:
greg
Vernon
Ah, never encountered that issue before - prefering my implement transmission shafts to be splined. One more reason to stay with what works I guess. Thanks for the clarification. Which implement manufacturer, if I may ask? It may save somebody else the same grief in the future.
//greg//
   / pto slip clutch #16
greg_g said:
Nope. The slip clutch always goes on the implement end. Too dangerous to have those exposed springs so close to the operator. Overrunning clutches (generally) go on the tractor end, slip clutches belong on the implement end.
//greg//
Not trying to argue with you, I am just a little confused. If a bolt happens to break or the nut came off wouldn't the spring shoot away from the clutch? If that is the case I would think you would want it pointed away from you towards the implement. If it was on the implement end it would fly towards the operator. Or is there some other danger with the springs? I have one on the tractor pto basically to protect my tractor. I have a 4010 and a 4 ft KK rotory cutter. Whenever I would kick in the pto the shock would break a roll pin in the universal joint on the driveshaft from the engine to transmission, even at idle. Now it kicks in smoothly without the jolt. I can't imagine what would happen if I hit something big with it without the clutch.
   / pto slip clutch #17
Greg.. would you be surprised if i told you that JD 1517, 1518, and 2018 mowers had a torque limiter at the front of the pto shaft? ( I've never seen that before... My howse has a slip clutch at the gearbox at the implement. )
Luckilly my ample flip down steel pto shield on my NH tractor completely shrouds the torque limiter.. makes me feelbetter.
Soundguy
//greg//
   / pto slip clutch
I also have a shroud to cover the tractor shaft end. Im wondering if the only reason for it to be on the impliment end is "safety". I would think it would be safer under the metal shroud.Just a thought.Al
   / pto slip clutch #19
greg
I have an old Bush Hog SQ series that is now obselete. I guess that someone might buy one at auction or road side however. Would like to have a newer one but this one is still serviceable although I need to replace a bent tail wheeel fork.
Vernon
   / pto slip clutch #20
Bedlam said:
Thanks for the reply.
with reference to http://www.agrisupplyco.com/cgi-bin/cgiitmls?m=ThisP&p=31951.000000&l=1
I thought that the bottom part was female and slipped over the male pto shaft that is on the tractor. And the top end in the pic is female and would except the female implement coupler.(basically in-line).
Does that seem to be right?
I understand the 'smooth" shaft one is for a pin.
Thanks again
Al
Generally the slip clutch is mounted on the implement side to make it easier to connect the PTO shaft to the tractor. If you had the clutch on the tractor end, each time you unhooked the implement, you would have to unbolt the clutch from the PTO shaft. If someone makes a quick disconnect clutch, or you use the same slip clutch for every attachment and just leave it on the tractors PTO shaft, then it wouldn't be a problem.
The clutch you posted the link to is a 1 3/8" diameter-6 spline male and 1 3/8" diameter-6 spline female clutch. That would be a normal 540 RPM PTO shaft clutch. If you're upgrading from a shear pin setup, I think you need the "smooth" 1 3/8" female, 6 spline 1 3/8" male. That setup would only work on the implement side.
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2015 Ford Transit Cargo Van (A55852)
2015 Ford Transit...
2018 FREIGHTLINER M2 106 26' REEFER BOX TRUCK (A54607)
2018 FREIGHTLINER...
(48) 1" X 2" X 87" TUBING (A54756)
(48) 1" X 2" X 87"...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
