PTO shaft sources
/ PTO shaft sources #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
Is there some place to pick these up at a reasonable price? These are ridiculously expensive everywhere I've seen them. These things can't have more than $10 worth of steel in them but they easy go for $100-200 depending on the length and beefiness. Seems like a whole lot to spend on a tube with a yoke on each end.
/ PTO shaft sources #2
www.northerntool.com has a reasonable selection of pto drives of different lengths and yoke configurations and my memory is that the prices were at the lower end of what you indicated.
www.ccmmachinery.com also has a pretty extensive selection and prices vary depending on the application. Mark is very knowledgeable and a nice guy to deal with. He should be able to tell you what you need. His prices are very competitive.
Hope this helps
/ PTO shaft sources #4
www.agri-supply.com cheap they have everything if you dont see it call. There store is like the walmart of farming. there retail prices are cheaper than wholesale on most stuff I've been in the one in florence sc.
/ PTO shaft sources #5
TSC has them.. as well as JD dealrs. I'm sure part of the money is for liability insurance....
soundguy
2 Row Cultivator (A64047)
2 Row Cultivator...
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61572)
2025 Hydraulic...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
