PTO shaft seal leak
   / PTO shaft seal leak #1
turbopiper
Hempstead, TX
2004 Mahindra 2310
Took the tractor (2004 Mahindra 2310), and tiller to a friends house to till his 1/2 acre garden. I had just finished the first pass of tilling when I noticed a leak on the ground, and found it was leaking from around the PTO shaft. I assumed I blew out the PTO shaft seal, as shown in the attached PDF files, that I scanned out of my service manual and parts catalog.
So, do you think I just need to order just the shaft seal and be done with it?
Does anyone know what may have caused the leak, or what is usually the cause of this type of leak?
I know it's hard to determine without looking at the parts to see what failed in this case. I know I will have to order the parts and trying to get an idea if I should order anything else. I haven't taken any tools to it as it was getting late last Sunday to tear into it and I have a day job to get to Monday morning. My friend live 45 miles away, so it's not an easy trip during the weekdays.
Thanks for any info on this.
Ted
Ted
Man, forgot to attach the PDF file
  • MAHINDRA TRACTOR MODEL #2310.pdf
   / PTO shaft seal leak #3
3 major causes of seal leaks:
1, age.. just plain wore out.
2, bad bearing, bearing wear allows play, which hogs seal out.
3, mechanical interference from debri wrapped around the shaft at the seal fact.. IE.. wires and vines can roll up and eat the seal out.
I'd check for up/down/side/side play on the pto stub.. any play.. and you have a bearing going..
soundguy
soundguy
Well the shaft was clean and clear of any debris.
It's hard to have the tractor over 45 miles away and not be able to get to it after work, because it's not on the way home from work. So it's up to just the weekends to go over, take out the PTO shaft and see what's up.
Thanks for the reply, at least now I know what to look for, or a better idea.
Ted
   / PTO shaft seal leak #5
Grab the stub and give it a few ynaks before pulling it.. you will know i fthe bearing is bad immediatly.
soundguy
   / PTO shaft seal leak #6
Hi Soundguy.
I've developed a leak at my PTO shaft on my Ford 3910. I think because of an out of balance/bent shaft on my brush hog. Do I have to crack the rear end to fix it?
   / PTO shaft seal leak #7
If the pto seal is bad, yeah.. the bearing carrier will have to be yanked and then the seal replaced.. but check the bearing too.
soundguy
   / PTO shaft seal leak #8
$5.40 for the seal and the rear axle has to come apart:eek: ???
I think I'll wait on that repair.
Thanks for the reply:D I learn something everyday.
   / PTO shaft seal leak #9
Why the rear axle?.. why not just the bearing carrier?
soundguy
   / PTO shaft seal leak #10
soundguy
Is that the part around the PTO shaft? I think I have to pull out my papers and look a bit closer. Is it a big job pulling the bearing carrier?
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
Pallet of (6) 8 Lug Misc Wheels (A51573)
Pallet of (6) 8...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
1067 (A53342)
1067 (A53342)
Gas Powered Air Compressor (A51573)
Gas Powered Air...
Antique Horse Drawn Plow (A51573)
Antique Horse...
