PTO shaft Pin
   / PTO shaft Pin #1
tdenny
Platinum Member
Seattle area
JD 855 4WD, HST
Hello All,
I have a small problem.
The good news/w3tcompact/icons/cool.gif is I've finally gotten the pin that keeps the brush hog drive attached to the PTO shaft unstuck.
<font color=red>The bad news </font color=red>/w3tcompact/icons/frown.gif is when I popped it loose I apparently lost some parts for it. I can't figure out how it goes back together. I'm obviously missing at least one small part for this thingy - whatever it might be called scientifically.
My questions are -
1) Can I easily get a new one of these jobbers?
2) If so does anybody have any suggestion where?
3) Are they usually standard sized?
Thanks for any help.
   / PTO shaft Pin #2
There are several sizes and designs, the easiest thing to do is take that half of the shaft with you to a GOOD farm dealer
and put it on the parts counter and ask for a new quick disconnect pin. Any dealer worth their salt will have them in stock. Some of the newer ones only have a button and a spring and are held in with a couple of punched places around the hole, the older ones may have a clip and two or three pieces. They should know.
   / PTO shaft Pin
Thanks joecdeere.
That's exactly the information I was searching for. I'd sure like to try this old hog once before I have to go buy a new one. Who knows maybe it will work as advertised.
When you say "farm dealer" are you referring to JD, Kubota, NH etc?
   / PTO shaft Pin #4
Any should do, I just meant to not go to the small lawn and garden center type, A "farm" dealer tends to sell a lot more PTO driven equipment that the small places, therefore would
tend to stock the repair parts
   / PTO shaft Pin
Thanks, I will head there this afternoon.
2012 Nissan NV2500HD Cargo Van (A51692)
2012 Nissan...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
DRIVE UP RAMPS (A53843)
DRIVE UP RAMPS...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
