PTO shaft Pin
   / PTO shaft Pin #1
tdenny
Platinum Member
Seattle area
JD 855 4WD, HST
Hello All,
I have a small problem.
The good news/w3tcompact/icons/cool.gif is I've finally gotten the pin that keeps the brush hog drive attached to the PTO shaft unstuck.
<font color=red>The bad news </font color=red>/w3tcompact/icons/frown.gif is when I popped it loose I apparently lost some parts for it. I can't figure out how it goes back together. I'm obviously missing at least one small part for this thingy - whatever it might be called scientifically.
My questions are -
1) Can I easily get a new one of these jobbers?
2) If so does anybody have any suggestion where?
3) Are they usually standard sized?
Thanks for any help.
   / PTO shaft Pin #2
There are several sizes and designs, the easiest thing to do is take that half of the shaft with you to a GOOD farm dealer
and put it on the parts counter and ask for a new quick disconnect pin. Any dealer worth their salt will have them in stock. Some of the newer ones only have a button and a spring and are held in with a couple of punched places around the hole, the older ones may have a clip and two or three pieces. They should know.
   / PTO shaft Pin
Thanks joecdeere.
That's exactly the information I was searching for. I'd sure like to try this old hog once before I have to go buy a new one. Who knows maybe it will work as advertised.
When you say "farm dealer" are you referring to JD, Kubota, NH etc?
   / PTO shaft Pin #4
Any should do, I just meant to not go to the small lawn and garden center type, A "farm" dealer tends to sell a lot more PTO driven equipment that the small places, therefore would
tend to stock the repair parts
   / PTO shaft Pin
Thanks, I will head there this afternoon.
1 pallet of miscellaneous hoses (A53117)
1 pallet of...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2012 Diamond Cargo Enclosed 24FT T/A Cargo Trailer (A51694)
2012 Diamond Cargo...
2011 Genie GRC-12 Man Lift (A53117)
2011 Genie GRC-12...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
