PTO shaft broken
/ PTO shaft broken #1
roller
Suffolk England
kIOTI CK30
I have a ck30 with broken/snapped shaft [internal],been told it was a manufacturing fault, and kioti have taken full resonsability no quibles their!!
Now this shaft broke 2 weeks today and i'm still waiting for it to be repaired ,apparently their STILL waiting for a few parts to come in from KOREA..
Anyone else heard of shafts snapping??
/ PTO shaft broken #3
Nope, and I have certainly killed the engine while brush mowing until I got the slip clutch properly adjusted.
/ PTO shaft broken #4
Never used mine. Hope it doesn't go the first time I do.
This is the first time I have heard of this problem being mentioned in this forum, so it looks like a unfortunate fluke to be the first! :mad: Good luck on your repairs.;)
/ PTO shaft broken #5
What were you running when it snapped, if you don't mine me asking? I'm Curious?
Steve
/ PTO shaft broken
Steve
Flail mower.
/ PTO shaft broken #7
Never heard of that either, Were you using slip clutch or shear bolt for protection?
/ PTO shaft broken #8
Broke PTO while using a flail mower? I'd say the belt(s) are too tight on your mower. I use a flail mower alot and have stalled it to the point of burning up the belts. The drive belt(s) are there to protect the mower gear box and the PTO/tractor. I've heard of broken PTO's but that was caused by sudden sock load i.e. 'tiller with no slip clutch or engaging the PTO at too high of engine RPM. So I would tend to believe that it was just a "fluke".
/ PTO shaft broken #9
are you sure the shaft broke? I have seen the internal over run clutch not working properly..... so the shaft doesn't drive.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
159118 (A60430)
159118 (A60430)
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2007 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2007 BIG TEX 16...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
