PTO shaft bolt removal
   / PTO shaft bolt removal #1
confederatemule
On a Rhino 172 rotary cutter I am not having any luck at removing the bolt that holds the shaft to the cutter gear box. The nut came off easy. I think the bolt is supposed to be easy to pull out. The bolt will barley turn, and then not very far. Is it so rusty that it will not turn? I see no evidence of rust. Do you suppose it has tried to sheer and therefore is no longer straight? It is the original factory bolt. The shaft has a slip clutch.
Thanks for any help.
   / PTO shaft bolt removal #3
Yes,
A punch and a big hammer should do the trick.
Also twisting the shaft / gear box shaft this bolt connects might help (if there is any free play between them)
   / PTO shaft bolt removal #4
First suspicion is the bolt tried to shear and won't come out easily because of that. Put some penetrating oil on it and let it soak for a bit. Then punch/hammer it out. Just watch your fingers. The gear box shaft may tend to move on you as you work on it.
   / PTO shaft bolt removal #5
I agree with the other posters. The bolt is partly sheared and the clutch is partly frozen/rusted to the gearbox shaft. Spray lube on the connection and keep working at it. (y)
   / PTO shaft bolt removal #6
Why worry about it? Just put a new bolt and two crescent wrenches in the tool box and keep going.
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
