Rotary Cutter PTO selection for mowing / shredding ?
/ PTO selection for mowing / shredding ? #1
txhillcountry
New Braunfels, TX
Zetor 6441
Hi all, the Zetor we have has two positions on the PTO (not counting Neutral).
One position is - Ground speed of PTO shaft (through gearbox) - PTO shaft speed depends upon the engaged gear speed
The other position is - Independent speed of PTO shaft - PTO shaft speed depends upon the engine speed (540 RPM PTO)
With respect to mowing, ie.. pulling a PTO driven "bush-hog" type shredder, which is recommended?
Aside from mowing, what are some examples of how or why you'd choose either of those positions?
Thanks!
/ PTO selection for mowing / shredding ? #2
You'd use your gear powered for planters, etc. that you want to slow down when the tractor does.
The PTO setting will keep a cutter or baler operating if you have to stop for a branch or fawn your path. It's easier on some equipment if it keeps spinning, esp if the PTO engagement is jerky.
On my old MF with both, I never used the ground-speed setting for mowing, etc.
Jim
/ PTO selection for mowing / shredding ? #3
This would use ground speed:
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Patterson water pump (A59230)
Patterson water...
Stout Brush Grapple 66-9 (A66285)
Stout Brush...
2021 YANMAR VIO35-6A EXCAVATOR (A63276)
2021 YANMAR...
Linx EQ7018RS Trailer (A65640)
Linx EQ7018RS...
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
