PTO seal leaking
/ PTO seal leaking #1
3gunr
wentzville mo
mahindra 2538 mahindra 2810 cub cadet 7260 massey 255
My mahindra 2538 pto seal has a slight leak, I have the new seal and am wondering if i should use some type of gasket sealer on the gasket or not
/ PTO seal leaking #2
I usually put a little oil or grease but mainly use whatever fluid it it restraining on the lip when installing seals.
/ PTO seal leaking #3
I only grease both sides of gasket, and inside of seal.
/ PTO seal leaking #4
Usually they don't leak unless the fluid in the gearbox is too high. It needs to be below the seal lip, or if the outboard bearing has excessive radial play.
/ PTO seal leaking
the hyd fluid sightglass is higher than the pto seal , so i assume the fluid is also so not sure what you mean by fluid being to high ?
/ PTO seal leaking
The sightglass is even with the top of the pto shaft The level fluid line is just above the shaft , So the lower 2/3 of the seal has fluid on it,
/ PTO seal leaking #8
I usually go by how the original gasket was installed. If it had some form of sealant I use some on the replacement. If not install it without.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2011 Blue Bird School Bus (A62613)
2011 Blue Bird...
2016 PITTS LP-40 4 BOLSTER LOG TRAILER (A64276)
2016 PITTS LP-40 4...
John Deere 3025E (A64126)
John Deere 3025E...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
